Activity › Forums › Apple Final Cut Pro Legacy › Deck Issues
Deck Issues
Posted by Caryn Johnson on February 10, 2007 at 5:52 pmI just rented a sony dsr-30 for a project I’m working on, but I can’t seem to get the firewire to communicate with my computer. I’m pretty sure it’s a deck issue (and I’ve tried the holding down the record/pause while turning it on trick). I know it’s probably something easy, but the rental didn’t come with the manual and I am just a bit tired of fooling with it. Can anyone help, please?
Caryn Johnson replied 19 years, 7 months ago 3 Members · 4 Replies -
Rob Forsythe
February 10, 2007 at 7:43 pmThis list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.
d. Being able to capture from a FW device.If working this list doesn’t cure the problem… you may have a serious PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Make sure you have chosen FW output for A/V:
Final Cut Pro (menu) > Audio/Video Settings… >
Video Playback: Apple FireWire NTSC (720 x480)
Audio Playback: FireWire DV
11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
15. Important: Quit FCP, then Restart FCP.
16. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729If you have “lost” your entire FW connection between the Mac and the device, go HERE:
https://docs.info.apple.com/article.html?artnum=301852>Then, start again at my “step 1” above.
Caryn Johnson
February 10, 2007 at 9:33 pmDear Rob:
I love you. I love you. I love you. I will name all my children after you. Rob. Roberto. Robbie, Jr. Robmeister. ALL OF THEM. Thank you so much. You’re in my will.
Bouncing Account needs new email address
February 10, 2007 at 11:01 pm[georgemsaru] “Dear Rob:
I love you. I love you. I love you. I will name all my children after you. Rob. Roberto. Robbie, Jr. Robmeister. ALL OF THEM. Thank you so much. You’re in my will.”
OK.
But did it WORK?
