Activity Forums Adobe Premiere Pro Deck doesn’t stop on timecode in capture mode
  • Deck doesn’t stop on timecode in capture mode
    Posted by Shaun Kendall on June 6, 2008 at 4:38 pm
    I was capturing a tape using a JVC BR-DV600U deck (which Premiere has listed in its 1394 control), but every time I went to type in a specific timecode for the tape to jump to, the deck would overshoot it and keep going.
    For example, if I was at 00;01;00;00 and wanted to go to 00;05;00;00, the deck would start fast-forwarding, but once it got to 00;05;00;00 it would just keep on going.
    Same thing if you try to go to a timecode prior to where you’re currently at.
    Does this sound like a problem with my deck, or is this an issue with Premiere?
    Thanks.
    Shaun Kendall replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
