Activity › Forums › Avid Media Composer › Deck control with MOJO
Posted by Doug Normington on June 14, 2007 at 7:24 pmHi,
I have a AVID MOJO system.
I want to hook it up to my Beta deck.
What do I need to buy to get deck control to my Beta deck
What do I need to buy to be able to digitize compnenet in from the Beta deck
AND where can I get this stuff?
NORMCO
Mark replied 19 years, 2 months ago 5 Members · 7 Replies -
Jon Zanone
June 14, 2007 at 9:43 pm[normco] “What do I need to buy to get deck control to my Beta deck”
You’ll need a serial/RS422 converter. Google ‘rosetta stone and machine control
[normco] “What do I need to buy to be able to digitize compnenet in from the Beta deck”
Is this an SDI Mojo or component mojo? If its a component model, you’ll need an Avid supplied component to S-Video cable. You should be able to order one for Avid or a reseller. If your mojo is SDI, you’ll need an RGB to SDI converter. Aja makes a good one, as does Miranda.
[normco] “AND where can I get this stuff?”
Just google the products I mentioned, and you’ll find a multitude of vendors…Jon
Rhewitt
June 15, 2007 at 2:59 am[normco] “What do I need to buy to be able to digitize compnenet in from the Beta deck”
Component video is standard on both the analogue and SDI Mojos using the cables supplied with the Mojo.
Rhewitt
June 15, 2007 at 3:00 am[normco] “What do I need to buy to be able to digitize compnenet in from the Beta deck”
Jon Zanone
June 16, 2007 at 1:57 pmThanks! When I bought my two analog Mojo’s, cables were extra…
Jon
“The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
Geraint Pari huws
June 20, 2007 at 8:21 pmdeck control runs from the pc, whatever your avid, softmc/mojo/adrenaline/nitris.
amheus
Geraint Pari huws
June 20, 2007 at 8:24 pmdeck control runs from the pc, whatever your avid, softmc/mojo/adrenaline/nitris.
amheus
Mark
June 28, 2007 at 10:03 amJon,
I believe the component cable is still extra when you purchase the standard Mojo. Mojo SDI comes with the cables.
I had a friend who is good at soldering build my cable. I went to a local electonics store and bought the svideo adapter. It took my friend roughly 10 minutes to solder the parts following the wiring diagram available on the Avid website….total cost was between 10 and 15$….Avid wanted 75$. I really appreciated the fact that Avid posted the wiring diagram on their website.
