Activity › Forums › Apple Final Cut Pro Legacy › deck control with hdcam
  • deck control with hdcam
    Posted by Chris Johnson on July 11, 2005 at 6:07 pm
    I am using FCP 5 with black magic HP Pro Deck link. I try to capture in HDcam and after I log the clip as it captures I keep getting time code breaks even though there is no time code break on the tape, and it breaks the clip up into several clips and even skips a few seconds around each break. Is there any way to bring the footage in as one clip?
    Thanks in advance
    Chris Johnson replied 21 years, 2 months ago 2 Members · 2 Replies
  • Paul Ingvarsson
    July 11, 2005 at 9:34 pm
    I’ve been doing this just today on the same setup as you have – with no problems.
    Are you trying to capture uncompresed HD to your internal drives? Obviously you won’t be able to do this – try the Blackmagic DVCPro HD 1080 codec in 8 bit and see if you get the same problems.
    Paul
    Freelance DS/Symphony
    London
  • Chris Johnson
    July 12, 2005 at 1:28 pm
    I am capturing to fire wire 800 drive. I tried switching the inputi to black magic 1080i-dvcpro HD & 1080i 50 8 bit. This did not work, however I noticed that it captured more footage before a timecode break occurred.
