Activity › Forums › Blackmagic Design › Deck control UVW-1200 Decklink SP
  • Deck control UVW-1200 Decklink SP
    Posted by J442533 on August 21, 2006 at 9:16 pm
    Hello,
    I’m curious to see if anyone on this board has successfully achieved deck control with a UVW-1200 using a keyspan high speed USB adaptor. I have followed the link below with no success. Luke Maslen seemed sure this setup would work.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=736986&archive=T
    I have already spoken to tech support from Keyspan and Mr. Lam from Blackmagic design. I’m running out of ideas. My current configuration is as follows.
    PowerPC G4 – Decklink SP (5.6.2) Final Cut Pro 5. Serial > USB (Keyspan 19HS) and UVW-1200 of course…
    I’ve tried all the protocols (9.6k – 19.2k etc…) with no success. Using the supplied Black Magic Deck control utility also did not respond. I’ve also tried this on a fresh instal of the OS and final cut. Am I missing something here?
    Thank you,
    John
    J442533 replied 20 years, 1 month ago 2 Members · 2 Replies
