Activity › Forums › Apple Final Cut Pro Legacy › Deck Control though a router
  • Deck Control though a router
    Posted by Subspecies on April 25, 2007 at 1:22 pm
    hi all,
    i’m running an older version of FCP (4.5) at a local news station.
    (in the creative dept) we are connected via a router and use DeckLink’s HD Plus capture cards which feeds into the Betacam SX (DNW-A75) deck (when routed appropriately).
    Now i can wild capture using FCP, but have no deck control – it reads the deck as a non-controllable device.
    I’m using the Blackmagic 8 or 10 bit setup.
    Anyone know if it’s possible to get deck control via a router?
    Help
    Walter Biscardi replied 19 years, 5 months ago 5 Members · 4 Replies
  • David Bogie
    April 25, 2007 at 4:03 pm
    See markertek and Comprehensive supply for a mutli-machine DV/FW controllers, there are several models on the market made by LairdTelemedia. This is an active device that routes DV from and to several machines and one edit controller via Firewire. A router does not do the same thing.
    bogiesan
  • Bob Flood
    April 25, 2007 at 4:08 pm
    Hi
    Deck control in a Broadcast environmnet is usually executed via An rs 422 connection using a specific control protocol (no doubt sony)
    Talk to your engineering dept about runing an RS422 cable from your BM card to the deck. If the deck is shared with another controller, like station automation or linear editing, you can get a simple switch to go between fcp and the other app
    hope this helps
    bee eph
  • Rennie Klymyk
    April 29, 2007 at 7:59 pm
    [dante pignetti] “Anyone know if it’s possible to get deck control via a router?”
    You can also use a device like a BlackBox switcher to route all your rs 422 connections from all decks to all work stations while you’re at ed it.
  • Walter Biscardi
    April 29, 2007 at 8:02 pm
    [dante pignetti] ”
    I don’t know about a router, but we use a Cat-5 Patch Panel with our four RS-422 decks to feed our three AJA Kona systems with zero issues.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
