Activity Forums Apple Final Cut Pro Legacy Deck control issue with BetaDeck / DecklinkSP and Keyspan USB adapter
  • Deck control issue with BetaDeck / DecklinkSP and Keyspan USB adapter
    Posted by Dragos on April 24, 2005 at 12:29 am
    To whom it may concern,
    I just purchased the rs-232 cable and adapter made by pipelinedigital. I plugged it into the keyspan USB serial adapter (with the latest drivers loaded) and then plugged that into a Sony Betacam UVW1200 player. I opened up Final Cut Pro and put my capture settings at “BlackMagic NTSC 29.97” and my Capture/Input settings to Blackmagic NTSC – 10 bit. (I ordered the BlackMagic DecklinkSP card for capture.) When I run FInal Cut Pro and try to log and capture it is saying “no communication” Have anyone run into this issue before? Thanks.
    Dragos replied 21 years, 5 months ago 3 Members · 4 Replies
  • Kevin
    April 24, 2005 at 4:51 am
    The Decklink SP snake has a built-in rs232 cable… just hook it directly to the beta deck. No usb adaptor needed.
    K
  • Dragos
    April 24, 2005 at 6:17 am
    The problem is that the UVW1200 doesn’t use rs232. It uses rs422. That’s why I got the usb to serial converter and then the cable with the adpater. That’s what others have recommended. I just can’t get the program to recognize it.
  • Joachim Blunck
    April 24, 2005 at 5:48 pm
    DeckLink SP does RS422. Note specs:
    https://www.blackmagic-design.net/products/sd/specs/
    If you mean RS232 for the Keyspan…
    1. Install Keyspan driver
    2. In FCP, go to Audio/Video Settings, and create a device control preset that references the Keyspan.
    (haven’t done it in awhile, but once the Keyspan is available, it should pop up as a choice in one of the device toggles)
    JB
    Blue Smoke & Mirrors Ltd.
    FCP Finishing
    Xsan Integration
    310-292-0416
  • Dragos
    April 24, 2005 at 6:51 pm
    Thanks, I’m up and running now.
