Activity Forums Blackmagic Design Deck control capture
  • Deck control capture
    Posted by Jeff Lessard on February 27, 2006 at 6:41 pm
    Hello,
    Back in december I posted about my deckcontrol problem but did not get any responses.
    My problem has gotten worse, I can no longer capture from the deckcontrol apps.
    some feedback would be appreciated.
    thanks,
    (original post):
    I am capturing some footage in the BM Deckcontrol. I randomly get the message: ” The communication with the deck was lost”.
    Never happened before. The only thing that has change in our setup is the deck we are using. Previously we had a Betacam PVW-2800. Now we are using a Betacam DVW-500.
    any ideas?
    Jeff
    G5 Dual 2,3ghz
    2,5 gig ram
    Decklink extreme
    Mediavault U-320
    Jeff Lessard replied 20 years, 6 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 28, 2006 at 5:14 am
    Hi Jeff,
    What version of our drivers do you have now?
    Delete the file “com.blackmagic-design.BlackmagicDeckControl.plist” that is located in ~/Library/Preferences/
    Also look in the folder /Library/Preferences and see if you have the file called “com.blackmagic-design.DeckLinkPrefsPanel.plist”. If so, delete that as well. See if this fixes the problem.
    If not:
    Create another user account with admin rights, log into that and see if the same thing happens.
    regards
    Kristian Lam
    Blackmagic Design
  • Jeff Lessard
    February 28, 2006 at 4:28 pm
    Hi Kristian,
    We are using version 5.4.2 of the drivers.
    I will try what you propose and let you know,
    thanks,
    Jeff
