Activity Forums Blackmagic Design Deck Control and Combustion
  • Deck Control and Combustion
    Posted by Christopher Tay on January 4, 2006 at 7:50 am
    Just wanna know if anyone has noticed this.
    On Windows, using the Deck Control tool, I captured a 5 secs PAL clips, which is 125 frames in total and I bring the clip into Combustion 4, it shows up as 138 frames.
    If I bring the clip into Adobe Premier Pro, it shows up as 125 frames.
    If I capture the clip in Adobe Premier Pro and I bring it into Combustion 4, it will show up as 125 frames.
    Is this a bug in Deck Control ?
    -chrispy
    Janis Jansons replied 20 years, 7 months ago 4 Members · 5 Replies
  • Margus Voll
    January 4, 2006 at 12:45 pm
    Maybe you could check framerate and format in Dec Control under Edit > Prefs
    Margus.
  • Christopher Tay
    January 4, 2006 at 2:36 pm
    I’ve checked the preferences and it is indeed set for PAL and 25fps.
    -chrispy
  • Pentti Kakkori
    January 4, 2006 at 6:04 pm
    I tried it as well. Almost same results as you. I got 11 frames extra when I went to Combustion 4. But what was most interesting, when I had burnt in timecode in the video there really were 11 extra frames!! I tried also Commotion and Quicktime player but they didn’t see those extra frames.
  • Christopher Tay
    January 5, 2006 at 1:49 am
    Thanks for confirming that Pena…at least it is a repeatable thing.
    Hopefully someone at Blackmagic can look into this.
    -chrispy
  • Janis Jansons
    January 5, 2006 at 6:52 am
    I’m curious if this also brings up any audio sync issue?
    Janis
