Activity › Forums › Apple Final Cut Pro Legacy › deck control
deck control
Posted by Dan Archer on August 20, 2006 at 6:29 pmHow does one control a beta deck from a laptop rig, for on the road editing?
do I need a AJA or something?Dan Archer replied 20 years, 1 month ago 3 Members · 6 Replies -
Steve Eisen
August 20, 2006 at 7:16 pmKeyspan USB/serial adapter plus mini Din 8 pin to RS-422 cable.
You can find the products you need here:
https://www.imagineproducts.com/hardware_mac.htmlYou can also use the AJA IO (LA).
Jeremy Garchow
August 21, 2006 at 3:40 amHow are you going to get video and audio into your system?
Dan Archer
August 21, 2006 at 7:22 pmI was thinking a Canopus converter box, but I am open to any other suggestion.
A cut is a cut & a dissolve is a disolve, and not just anybody with a system is a pro.
Jeremy Garchow
August 21, 2006 at 11:04 pmIf I were you I’d get an io or an io/la or io/ld. It’s everything you need in one box.
Jeremy
Dan Archer
August 22, 2006 at 12:54 amafter my last post, I searchd the net for just that kind of stuff and found
the AJA boxes you mentioned. I already hane a Lhe on my Quadcore and love it. I will probably go with AJA.
