Activity Forums Broadcasting Deck Connections
  • Deck Connections
    Posted by Eric Nicastro on April 13, 2009 at 7:33 pm
    I have an Avid Media Composer with a Mojo SDI. It’s hooked up to a Sony UVW-1800 with the component connections. The display on the deck keeps saying No REF! and my monitor can’t keep the picture in alignment. Obviously it’s out of sync but how or what do I need to fix this problem?
    Grinner Hester replied 17 years, 4 months ago 3 Members · 2 Replies
  • Tom Mathews
    April 14, 2009 at 9:34 pm
    Your deck has given you your answer. It needs a reference signal. I’m afraId I don’t know your kit, but the deck should have a BNC connection marked “ref”. If your mojo has a ref out then simply hook the two up. If not then you’ll need a black burst generator to generate a reference signal.
    Good luck.
    Tom
  • Grinner Hester
    April 16, 2009 at 4:31 pm
    You have only hooked up audio and video and have not hooked up your black burst yet.
