Activity Forums Boris FX Deciphering Correct BCC version
  • Deciphering Correct BCC version
    Posted by Alberto Mendez on August 19, 2009 at 12:53 am
    I am using Avid MC composer 3.0 and Borix 5.0.3 Avx 2 plugins. I am working on a project with another company and a couple of FX they had in their sequence came up missing in the timeline. The FX is rendered and it looks like a BCC Fx but when I go into FX mode the Avid doesn’t tell me what fx it is. Is there a work-around to see what version of BCC they have. I’ve asked but I think they are giving me the wrong version (5.0.4). I took the update but the icons still do not show up in my timeline even after I break the render
    Alberto Mendez replied 17 years, 1 month ago 3 Members · 5 Replies
  • Matt Mullen
    August 19, 2009 at 5:17 pm
    Alberto,
    Do you know if they are using AVX 1.5 or AVX 2 versions of the plug-ins?
    Do you know if you have both versions installed?
    If you park on an effect and open the effect editor can you promote the effect? There should be a button for promoting to advanced key frames, does this show up?
  • Peter Mcauley
    August 19, 2009 at 5:20 pm
    Hi Alberto,
    Are you on Windows or Macintosh?
    Peter.
  • Peter Mcauley
    August 19, 2009 at 6:26 pm
    Hi Alberto,
    If you are on Windows:
    go to c:\program files\Boris FX, Inc\Boris Continuum Complete AVX 5.0\BCC 16bit Dlls
    then right click on the file that is in this folder, which should be labeled “BCC_16bit.dll”
    then click on the Version tab in the window that appears and you should see the exact version number
    If you are on Macintosh:
    go to MacintoshHD/Library/Application Support/BorisFX/Lib/BCC5AVX/BitDepthSupport/
    then click on the file BCC_Colors16bit.bundle and select file>get info and in the window that appears you should see the exact version number
    I hope this helps,
    Peter.
  • Alberto Mendez
    August 21, 2009 at 3:58 pm
    Sorry for the late response
    I have a mac based system (quad core) running MC 3.0 and I checked the version of BCC I am running.
    It’s BCC AVX2 (AVX 5.0.4). I haven’t been able to check their PC avids but now that I know how to get to the files, It should be easy to figure out now.
    thanks,
  • Alberto Mendez
    August 23, 2009 at 5:16 pm
    Just checked the clients version on their pc. It is version 5.0.3.56
    there is a conflict. I’ll have to down-grade to that version.
    thanks,
