Activity Forums Apple OS X Deciphering a system crash log
  • Deciphering a system crash log
    Posted by Keaton Douglas on September 28, 2012 at 4:55 pm
    Yesterday I inserted two new bare Seagate hard drives into my CRU-DataPort hard drive enclosure. The hard drive enclosure is connected to my Mac through eSATA wires connected into a Sonnet – Tempo eSATA Card. When I did this the computer crashed. I’m trying to determine if the problem is with the hard drives, the hard drive enclosure, or the eSATA card. When I turned my Mac back on the error report had a line near the top which said:
    Kernel Extensions in backtrace:
    com.sonnettech.driver.SonnetSATA(2.2.9)[A9109DE1-505C-C860-5298-0671E04C094A]@0xffffff7f807d7000->0xffffff7f807f5fff
    dependency: com.apple.iokit.IOATAFamily(2.5.1)[E5DB1B56-E922-3C25-B329-E1B34C591589]@0xffffff7f8076c000
    dependency: com.apple.iokit.IOPCIFamily(2.6.8)[F63D4ABE-42DA-33EF-BADD-3415B0CB0179]@0xffffff7f807aa000
    Can I assume based on this line that the error lies at the card? Or can I not determine it from this.
    The reason I’m having so much trouble diagnosing this is because sometimes all of this works, and sometimes all of it doesn’t. I’ve already destroyed three brand-new hard drives by using this setup… but maybe I just keep getting bad batches of drives.
    The full error report:
    Interval Since Last Panic Report: 1374796 sec
    Panics Since Last Report: 4
    Anonymous UUID: 50DF4331-F7AF-4F1B-AC29-C663159EBB5E
    Thu Sep 27 18:39:40 2012
    panic(cpu 14 caller 0xffffff80002c473a): Kernel trap at 0xffffff7f807e5009, type 13=general protection, registers:
    CR0: 0x000000008001003b, CR2: 0x000000010739a868, CR3: 0x0000000000100000, CR4: 0x0000000000000660
    RAX: 0xffffff80255a8800, RBX: 0xffffff8144e5bec0, RCX: 0x00000000015d0000, RDX: 0xffffff80195ce620
    RSP: 0xffffff8144e5bdf0, RBP: 0xffffff8144e5be30, RSI: 0xffffff8019568b00, RDI: 0xffffff801aeb8000
    R8: 0x0000000000000000, R9: 0xffffff801a0485a0, R10: 0x0000000000000322, R11: 0x0000000000ffffff
    R12: 0xffffff801aeb8000, R13: 0xffffff8120337000, R14: 0x0000000000000001, R15: 0xffffff7f807e49f8
    RFL: 0x0000000000010296, RIP: 0xffffff7f807e5009, CS: 0x0000000000000008, SS: 0x0000000000000010
    CR2: 0x000000010739a868, Error code: 0x0000000000000000, Faulting CPU: 0xe
    Backtrace (CPU 14), Frame : Return Address
    0xffffff8144e5baa0 : 0xffffff8000220792
    0xffffff8144e5bb20 : 0xffffff80002c473a
    0xffffff8144e5bcd0 : 0xffffff80002da0cd
    0xffffff8144e5bcf0 : 0xffffff7f807e5009
    0xffffff8144e5be30 : 0xffffff7f807e4a28
    0xffffff8144e5be60 : 0xffffff7f807da057
    0xffffff8144e5bf00 : 0xffffff7f807db375
    0xffffff8144e5bf20 : 0xffffff7f807e57e6
    0xffffff8144e5bf70 : 0xffffff7f807e6d69
    0xffffff8144e5bfa0 : 0xffffff7f807e5399
    0xffffff8144e5bfb0 : 0xffffff8000820057
    BSD process name corresponding to current thread: kernel_task
    Mac OS version:
    11E53
    Kernel version:
    Darwin Kernel Version 11.4.0: Mon Apr 9 19:32:15 PDT 2012; root:xnu-1699.26.8~1/RELEASE_X86_64
    Kernel UUID: A8ED611D-FB0F-3729-8392-E7A32C5E7D74
    System model name: MacPro4,1 (Mac-F221BEC8)
    System uptime in nanoseconds: 9245337519940
    last loaded kext at 6342071770240: com.apple.driver.AppleFireWireStorage 3.0.1 (addr 0xffffff7f80827000, size 16384)
    last unloaded kext at 7380214668658: com.sonnettech.SonnetSATABlockStorage 2.2.9 (addr 0xffffff7f807c8000, size 61440)
    loaded kexts:
    com.paceap.kext.pacesupport.snowleopard 5.8
    com.sonnettech.driver.SonnetSATA 2.2.9
    com.blackmagic-design.desktopvideo.iokit.driver 9.6
    com.blackmagic-design.desktopvideo.iokit.framebufferdriver 9.6
    com.blackmagic-design.desktopvideo.iokit.decklinkhddriver 1.0.0
    com.SiliconImage.driver.Si3132 1.2.5
    com.apple.driver.Oxford_Semi 3.0.1
    com.apple.filesystems.afpfs 9.8.1
    com.apple.nke.asp_tcp 6.0.1
    com.apple.driver.AppleHWSensor 1.9.5d0
    com.apple.filesystems.autofs 3.0
    com.apple.driver.AudioAUUC 1.59
    com.apple.iokit.IOUserEthernet 1.0.0d1
    com.apple.iokit.IOBluetoothSerialManager 4.0.5f11
    com.apple.Dont_Steal_Mac_OS_X 7.0.0
    com.apple.driver.AppleTyMCEDriver 1.0.2d2
    com.apple.driver.AGPM 100.12.42
    com.apple.driver.AppleMikeyHIDDriver 122
    com.apple.driver.AppleMikeyDriver 2.2.0f3
    com.apple.driver.AppleHDA 2.2.0f3
    com.apple.driver.AppleUpstreamUserClient 3.5.9
    com.apple.driver.AppleMCCSControl 1.0.26
    com.apple.driver.AirPort.Atheros21 431.14.10
    com.apple.GeForce 7.1.8
    com.apple.driver.ACPI_SMC_PlatformPlugin 5.0.0d0
    com.apple.driver.AppleLPC 1.5.8
    com.apple.driver.AudioIPCDriver 1.2.2
    com.apple.driver.BroadcomUSBBluetoothHCIController 4.0.5f11
    com.apple.driver.XsanFilter 404
    com.apple.iokit.IOAHCIBlockStorage 2.0.3
    com.apple.iokit.SCSITaskUserClient 3.2.0
    com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
    com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0d1
    com.apple.BootCache 33
    com.apple.iokit.IOAHCISerialATAPI 2.0.3
    com.apple.driver.AppleFWOHCI 4.8.9
    com.apple.driver.AppleAHCIPort 2.3.0
    com.apple.driver.AppleUSBHub 4.5.0
    com.apple.driver.Intel82574L 2.2.0b2
    com.apple.driver.AppleUSBEHCI 4.5.8
    com.apple.driver.AppleUSBUHCI 4.4.5
    com.apple.driver.AppleEFINVRAM 1.5.0
    com.apple.driver.AppleRTC 1.5
    com.apple.driver.AppleHPET 1.6
    com.apple.driver.AppleACPIButtons 1.5
    com.apple.driver.AppleSMBIOS 1.8
    com.apple.driver.AppleACPIEC 1.5
    com.apple.driver.AppleAPIC 1.5
    com.apple.driver.AppleIntelCPUPowerManagementClient 193.0.0
    com.apple.nke.applicationfirewall 3.2.30
    com.apple.security.quarantine 1.3
    com.apple.driver.AppleIntelCPUPowerManagement 193.0.0
    com.apple.iokit.IOSCSIBlockCommandsDevice 3.2.0
    com.apple.iokit.IOFireWireSerialBusProtocolTransport 2.1.0
    com.apple.iokit.IOFireWireSBP2 4.2.0
    com.apple.security.SecureRemotePassword 1.0
    com.apple.kext.triggers 1.0
    com.apple.iokit.IOSurface 80.0.2
    com.apple.driver.DspFuncLib 2.2.0f3
    com.apple.driver.AppleSMBusController 1.0.10d0
    com.apple.iokit.IOATAFamily 2.5.1
    com.apple.iokit.IOFireWireIP 2.2.4
    com.apple.iokit.IOSerialFamily 10.0.5
    com.apple.driver.AppleHDAController 2.2.0f3
    com.apple.iokit.IOHDAFamily 2.2.0f3
    com.apple.iokit.IO80211Family 420.3
    com.apple.driver.AppleSMC 3.1.3d8
    com.apple.driver.IOPlatformPluginLegacy 5.0.0d0
    com.apple.driver.AppleSMBusPCI 1.0.10d0
    com.apple.driver.IOPlatformPluginFamily 5.1.0d17
    com.apple.nvidia.nv50hal 7.1.8
    com.apple.NVDAResman 7.1.8
    com.apple.iokit.IOAudioFamily 1.8.6fc17
    com.apple.kext.OSvKernDSPLib 1.3
    com.apple.driver.ApplePolicyControl 3.0.16
    com.apple.driver.AppleGraphicsControl 3.0.16
    com.apple.iokit.IONDRVSupport 2.3.2
    com.apple.iokit.IOGraphicsFamily 2.3.2
    com.apple.driver.AppleUSBHIDMouse 170.4
    com.apple.driver.AppleHIDMouse 170.4
    com.apple.driver.AppleUSBBluetoothHCIController 4.0.5f11
    com.apple.iokit.IOBluetoothFamily 4.0.5f11
    com.apple.driver.AppleUSBHIDKeyboard 160.7
    com.apple.driver.AppleHIDKeyboard 160.7
    com.apple.iokit.IOUSBHIDDriver 4.4.5
    com.apple.driver.AppleUSBMergeNub 4.5.3
    com.apple.driver.AppleUSBComposite 4.5.8
    com.apple.iokit.IOSCSIMultimediaCommandsDevice 3.2.0
    com.apple.iokit.IOBDStorageFamily 1.6
    com.apple.iokit.IODVDStorageFamily 1.7
    com.apple.iokit.IOCDStorageFamily 1.7
    com.apple.iokit.IOSCSIParallelFamily 2.5.1
    com.apple.iokit.IOSCSIArchitectureModelFamily 3.2.0
    com.apple.iokit.IOFireWireFamily 4.4.5
    com.apple.iokit.IOAHCIFamily 2.0.8
    com.apple.iokit.IOUSBUserClient 4.5.8
    com.apple.iokit.IONetworkingFamily 2.1
    com.apple.iokit.IOUSBFamily 4.5.8
    com.apple.driver.AppleEFIRuntime 1.5.0
    com.apple.iokit.IOHIDFamily 1.7.1
    com.apple.iokit.IOSMBusFamily 1.1
    com.apple.security.sandbox 177.5
    com.apple.kext.AppleMatch 1.0.0d1
    com.apple.security.TMSafetyNet 7
    com.apple.driver.DiskImages 331.6
    com.apple.iokit.IOStorageFamily 1.7.1
    com.apple.driver.AppleKeyStore 28.18
    com.apple.driver.AppleACPIPlatform 1.5
    com.apple.iokit.IOPCIFamily 2.6.8
    com.apple.iokit.IOACPIFamily 1.4
    Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2.26 GHz, 11 GB, SMC 1.39f5
    Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
    Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
    Memory Module: DIMM 2, 1 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x394A53463132383732415A2D314731463120
    Memory Module: DIMM 3, 1 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x394A53463132383732415A2D314731463120
    Memory Module: DIMM 4, 1 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x394A53463132383732415A2D314731443120
    Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
    Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
    Memory Module: DIMM 7, 1 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x394A53463132383732415A2D314731463120
    Memory Module: DIMM 8, 1 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x394A53463132383732415A2D314731443120
    AirPort: spairport_wireless_card_type_airport_extreme, Atheros 5416: 2.1.14.9
    Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
    Network Service: AirPort, AirPort, en2
    PCI Card: Sonnet Tempo SATA E4P, sppci_ide, Slot-3
    PCI Card: pci1095,3132, sppci_sata, Slot-4
    PCI Card: NVIDIA GeForce GT 120, sppci_displaycontroller, Slot-1
    PCI Card: pcibdbd,a120, sppci_video, Slot-2
    Serial ATA Device: HL-DT-ST DVD-RW GH41N
    Serial ATA Device: Hitachi HDE721010SLA330, 1 TB
    USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd300000 / 2
    USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfd330000 / 4
    USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd320000 / 3
    USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 / 2
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 3
    FireWire Device: My Book, WD, 800mbit_speed
    FireWire Device: built-in_hub, 800mbit_speed
    Steve Modica replied 13 years, 10 months ago 2 Members · 1 Reply
  • Steve Modica
    October 27, 2012 at 12:35 pm
    It’s probably safe to assume that this is a sonnet driver bug. The next step would be to set keep_syms to 1 in nvram (google for the exact syntax). Then you’ll see the stack trace get filled in rather than being a bunch of hex addresses. Send this to sonnet for review. (what you have not isn’t very useful to them).
    The kernel log may have other useful information (/var/log/kernel.log).
    Steve Modica
    CTO, Small Tree Communications
