Activity Forums Apple Final Cut Pro Legacy Deciphering a crash (constantly) report—???
  • Deciphering a crash (constantly) report—???
    Posted by Phillip Powell on October 23, 2007 at 7:25 pm
    Any ideas be a big help as Apple don’t make it easy to figure these things out.
    Happens when rendering, or exporting to Compressor or just editing. Tried the usual:
    -deleted prefs
    -re-set PRAM
    -changed drives to render to
    Here’s the crash report, and thanks in advance for any clue, p2:
    Date/Time: 2007-10-23 11:45:23.331 -0700
    OS Version: 10.4.9 (Build 8P4037)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [55]
    Version: 6.0.1 (6.0.1)
    Build Version: 3
    Project Name: FCPApp
    Source Version: 706230001
    PID: 208
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_INVALID_ADDRESS (0x0001) at 0xd1c54350
    Thread 0 Crashed:
    0 …ickTimeComponents.component 0x981a610c Decompress24to32AR + 350
    1 …ickTimeComponents.component 0x981990ec RLE_DDrawBand + 243
    2 …ple.CoreServices.CarbonCore 0x90cd0b0f CallComponentFunctionCommon + 513
    3 …ickTimeComponents.component 0x98196c4e RLE_DComponentDispatch + 170
    4 …ple.CoreServices.CarbonCore 0x90cd07f4 CallComponentDispatch + 34
    5 …ickTimeComponents.component 0x98afae8b ImageCodecDrawBand + 43
    6 …ickTimeComponents.component 0x980b8ac0 BaseCodec_DecompressWorkFunction + 1006
    7 …ple.CoreServices.CarbonCore 0x90cdc9b6 InvokeComponentMPWorkFunctionUPP + 22
    8 …ickTimeComponents.component 0x980b6963 BaseCodec_DecompressCallBack_Common + 980
    9 …ickTimeComponents.component 0x980ba8e0 Base_CDBandDecompress + 7154
    10 …ple.CoreServices.CarbonCore 0x90cd0b0f CallComponentFunctionCommon + 513
    11 …ickTimeComponents.component 0x980b526d Base_CDComponentDispatch
    ….and on and on. Here’s mosheen’s specs:
    Model: MacPro2,1, BootROM MP21.007F.B02, 8 processors, Quad-Core Intel Xeon, 3 GHz, 8 GB
    Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
    Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser A/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz
    Bluetooth: Version 1.7.14f14, 2 service, 1 devices, 1 incoming serial ports
    PCI Card: Sonnet Tempo SATA E4P, sppci_ide, Slot-4
    PCI Card: ATY,RadeonX1900, Display, Slot-1
    Serial ATA Device: ST3750640AS, 698.64 GB
    Serial ATA Device: WDC WD2500AAJS-41RYA0, 232.89 GB
    Serial ATA Device: HDS725050KLA360, 465.76 GB
    Parallel ATA Device: OPTIARC DVD RW AD-7170A
    USB Device: Bluetooth HCI, Up to 12 Mb/sec, 500 mA
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: Apple Optical USB Mouse, Mitsumi Electric, Up to 1.5 Mb/sec, 100 mA
    USB Device: USB Trackball, Logitech, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    FireWire Device: Io, AJA Video Systems, Inc., Up to 400 Mb/sec
    FireWire Device: My Book Device, WD, Up to 800 Mb/sec
    FireWire Device: built-in_hub, unknown_value, Unknown
    FireWire Device: OWC Mercury Elite-AL 1, Other World Computing, Up to 800 Mb/sec
    Jeremy Garchow replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 23, 2007 at 7:41 pm
    Looks like you have a lot on your firewire ports, including an io and multiple fw drives. That’s not really recommended.
    Do you have your Expansion Slot Utility setup properly?
    Do you have any third party codecs installed, such as Avid codecs?
