Activity Forums Apple Final Cut Pro Legacy Deciding between sequence set at NTSC 3:2 OR NTSC DV 4:3
  • Deciding between sequence set at NTSC 3:2 OR NTSC DV 4:3
    Posted by David Notowitz on March 17, 2010 at 7:08 pm
    It’s been awhile since I worked with SD, and I need to choose a setting for creating and outputting a photo/(archive) video montage to DVD for projection on standard definition video.
    For best final quality of image, should I set my sequence to NTSC 3:2 or NTSC DV 4:3?
    Besides the obvious difference with ratio, what is the difference?
    David Notowitz
    Notowitz Productions
    We capture the memories that make life worth living.
    https://www.Notowitz.com
    David Notowitz replied 16 years, 6 months ago 2 Members · 2 Replies
  • Chris Borjis
    March 17, 2010 at 7:09 pm
    Well if your sequence is DV then leave the preset what it is.
    I would do it in prores. again leaving that ratio alone.
  • David Notowitz
    March 17, 2010 at 7:50 pm
    Thank you so much. I’ll change the compression to Pro-Res but keep the ratio as it currently is.
    Anyone else with thoughts?
    Have a great day!
    Inspiring Action™
