Activity Forums Adobe After Effects Expressions decaying bounce off imaginary wall
  • decaying bounce off imaginary wall
    Posted by Barry Suydam on April 15, 2011 at 1:09 pm
    I have a verticle thin line with its anchor point set at the top of the viewable composition. what I am trying to attain is to have it rotate into its virticle position with a decaying bounce off an imaginary wall. Any help? So far I have this expression applied but it swings through the imaginary wall.
    veloc = -50
    amplitude = -90
    decay = 4;
    y = amplitude*Math.cos(veloc*time)/Math.exp(decay*time);
    value + y
    Dan Ebberts replied 15 years, 4 months ago 2 Members · 6 Replies
  • Dan Ebberts
    April 15, 2011 at 4:00 pm
    Just change the 4th line to this:
    y = -Math.abs(amplitude*Math.cos(veloc*time)/Math.exp(decay*time));
    Dan
  • Barry Suydam
    April 15, 2011 at 6:06 pm
    Thanks again….you are great!
  • Barry Suydam
    April 15, 2011 at 7:04 pm
    I have a text layer that after a time passes in the comp I want it to start a decaying swing and land perpendicular to its start point. Any help would be great.
  • Dan Ebberts
    April 15, 2011 at 7:20 pm
    Like this, probably:
    timeToStart = 3;
    veloc = -50
    amplitude = -90
    decay = 4;
    t = Math.max(0,time-timeToStart);
    y = -Math.abs(amplitude*Math.cos(veloc*t)/Math.exp(decay*t));
    value + y
    Dan
  • Barry Suydam
    April 15, 2011 at 7:27 pm
    I thank you again.
    The world of after effects expressions is lucky to have a person like you to be able to throw out a problem and have a solution so fast. I am not sure where you live or who you work for but thank you. I have a fair understanding of expressions because of your website and jjgifford.com, much appreciated. Is there another resource like those that I haven’t found. I just wish I could do better and more with applying expressions. I wish I worked with some more folks like you.
    -Barry
  • Dan Ebberts
    April 15, 2011 at 7:39 pm
    Thanks for the kind words Barry, I appreciate it.
    I’m afraid I haven’t kept track of what’s out there. I am working on a long-overdue update to my own site that should make it a much better resource.
    Dan
