Activity Forums Adobe After Effects Expressions Decay sinusoidal between 2 values
  • Xavier Gomez
    November 30, 2012 at 12:40 am
    It is a misprint, you misplaced a parenthesis:
    case 0:
    if (… == 0) >>> ok
    else >>> not ok : replace (opacidad_maxima-opacidad_minima /2) by (opacidad_maxima-opacidad_minima)/2
    But even if you do that you will get a value of opacity = opacidad_maxima (80) at time=0;
    Apparently you want opacity = opacidad_minima at t=0, so set the phase at 180° and push up opacidad_maxim (to ~89) otherwise the opacity will never reach 80.
    Xavier
  • Eden Exposito
    December 1, 2012 at 11:32 am
    Woh!
    Thanks for your response!! i did not see it
    Thanks for your time
