Activity › Forums › Adobe After Effects › debugging multiple files
  • debugging multiple files
    Posted by Knubile on June 10, 2006 at 8:36 pm
    I have a library of script files that work together to fill keyframes in a project file.
    Using the extend script toolkit to debug has proven to be a little weak.
    I have script A and it references script B with a #include statement.
    The debugger won’t stop at breakpoints in script B when I run script A. Is there an option I’m missing perhaps?
    Bascule replied 20 years, 3 months ago 2 Members · 1 Reply
  • Bascule
    June 12, 2006 at 12:55 pm
    If you put a breakpoint on the line where A calls B, and step into B, breakpoints you add to script B should now work.
    Strangely, pasting all the code into one big file doesn’t always work either. I guess the debugger gets confused with large scripts.
