Activity › Forums › Adobe After Effects Expressions › Debugging an expression (square root trouble?)
  • Debugging an expression (square root trouble?)
    Posted by Michael Tammaro on August 14, 2014 at 2:46 pm
    I have a complex expression that I will be applying to hundreds of layers, and there is a bug. Through a bit of experimenting, I’ve deduced that knowing how to fix the bug in the following expression would be sufficient for my needs:
    x0 = 1; y0 = 2; r1 = Math.sqrt((745 – x0)*(745 – x0) + (660 – y0)*(660 – y0)); x = r1 + x0; y =r1 + y0; [x,y]
    Any help would be appreciated!
    Michael Tammaro replied 12 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 14, 2014 at 3:54 pm
    Somehow you ended up with em dashes instead of minus signs. Try it this way:
    Dan
  • Michael Tammaro
    August 15, 2014 at 1:43 am
    Thanks so much, Dan. Initially I had written the expression out in word, then copied it into AE. I tried trying the expression directly into AE, using the default “-” on my keyboard, and the expression worked. I might not have tried that without your feedback, so thanks again.
