Activity › Forums › Apple Final Cut Pro Legacy › Dealing with super whites
  • Dealing with super whites
    Posted by Aaron Neitz on January 4, 2008 at 10:26 pm
    So we’re working on a hvx-200 project. And obviously I’ve got information above 700mv. When I export QT’s out of the project to use in After Effects(etc…) those programs clip the white @ 100%. Should I be applying a color correct to these clips and pulling down the whites before exporting? Since all the whites go as a range, it seems to makes a smoother transistions than just clipping the max values.
    Or is there a better way to deal with super-white when going in and out of effects software?
    thanks!
    Jeremy Garchow replied 18 years, 8 months ago 4 Members · 3 Replies
  • Paul Escandon
    January 4, 2008 at 10:53 pm
    Are you setting the depth in after effects to use float space (32-bit?). I’m thinking that you need to not be working in 8-bit to preserve super whites. I might be totally off here – but have you given that a shot?
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Chris Borjis
    January 5, 2008 at 12:14 am
    somewhere in AE there’s a setting preference for the footage, change it to REC 709 or HD color space (can’t recall what its called) that might do the trick.
  • Jeremy Garchow
    January 8, 2008 at 4:43 am
    I think that’s the deal from going from YUV to RGB and back when exporting from FCP. How are you exporting and to what codec? Have you pulled those exported clips back in and seen if those are clipped? It could be quicktime as well that’s doing the clipping. It wouldn’t surprise me.
    Jeremy
