Activity › Forums › Avid Media Composer › Dealing with camera audio
Posted by Pieter Viljoen on June 24, 2013 at 6:55 amI am doing a favor for someone that recorded an interview outside in the street with a strong wind blowing as you can guess it sounds just incredible. All I can think of is to get into the 16 band EQ and try to bring down some of the noise. What techniques, within 6.5, am I overlooking? Thank you so much
Robert Ober replied 13 years, 2 months ago 3 Members · 16 Replies -
Peter Groom
June 24, 2013 at 9:28 amHi
what exactly does it sound like. Overloaded bottom end?
Its not within avid but i use izotope RX to clean up audio like what i suspect this sounds like quite often . The problem with eq is it takes all audio out at a given frequncy, tather than isolating a particular problem
If you upload a short clip that has the problem ill have a look for you.
PeterPost Production Dubbing Mixer
Robert Ober
June 24, 2013 at 10:14 pmYes, What Peter said.
Also, what I first do is sample the noise in a noise reduction plugin if possible to element most or all of the background noise. This of course in an audio program such as Audition. Not sure there is such a plugin in MC or Symphony.
Audacity is free and I believe it has such a plugin.
As far as EQ goes, it depends on the noise characteristics but often you can make progress by rolling off the low frequencies. I did that with some windy beach footage a friend of mine shot.
Hope that helps,
Robert A. Ober -
Pieter Viljoen
June 25, 2013 at 9:30 pmHi Peter,
password is creativecow
Thanks so much for your help. I just included audio that gives you a good sampling of the issue, and Vimeo is the final delivery format so it’s as compressed as it’s going to be.
Peter Groom
June 26, 2013 at 3:24 pmOk Peter
I have a sound file to go back to you. when can i email it?
Pieter Viljoen
June 26, 2013 at 5:46 pmsure, is my contact info listed here? Are there private messages on creative cow?
Peter Groom
June 26, 2013 at 8:26 pmHI
I dont see any contact details on your profile. I looked.
Dont think pms are on here no.
youll need to contact me at peter@denefilms.com
