Activity Forums Apple Final Cut Pro Legacy Dead Audio Meters
  • Dead Audio Meters
    Posted by Dcribber on April 11, 2005 at 3:03 pm
    I have dead audio meters. It’s sad. I hear audio. I capture audio. I just don’t see audio. I am running through an AJA IO that I am not intimately familiar with yet. The meters are only dead when the Log & Capture window is open. Once I capture a clip and place it in the timeline, the levels start bouncing around again like nothing is wrong. Sure enough though when I re-open the Log and Capture window and start playing the tapes, I get no siganl from the meters. What am I doing wrong?
    DaveC
    Bret Williams replied 21 years, 5 months ago 3 Members · 3 Replies
  • John Grilli
    April 11, 2005 at 3:13 pm
    When in Log & Capture, under the clip settings, open up the waveform and vector scope tab and POOF! the meters will show up.
  • Dcribber
    April 11, 2005 at 3:50 pm
    Well that solution worked. I am not sure why, but it worked and I thank you. The aduio meters were always there, but were just not responding until I turned on the waverforms and scopes.
    DaveC
  • Bret Williams
    April 11, 2005 at 10:10 pm
    Correct. That’s how AJA works.
