Activity Forums Apple Final Cut Pro Legacy Deactivating FX in multiple clips
  • Deactivating FX in multiple clips
    Posted by Sascha Engel on February 16, 2011 at 4:36 pm
    Hi Everybody,
    a Q concerning FX in clips on timeline: I know, how to remove multiple filter in multiple clips at once, by right clicking and choose remove attributes.
    How can I do the same operation, but not removing them, but just switching them off?
    Thanx.
    Sascha
    John Pale replied 15 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Pale
    February 16, 2011 at 4:42 pm
    No function for that, but how about duplicating the sequence and removing the effects from the duplicate.
  • Sascha Engel
    February 16, 2011 at 5:15 pm
    Thanx. Yes, I thought about that as well, but if I want to e.g. re-position clips or do other things with them – which are easier & faster when the effects are off, how do I get those adjustments then quickly back to the SEQ where the FX are turned on?
    Sascha
  • David Roth weiss
    February 16, 2011 at 5:38 pm
    In the RT drop-down over on the left side of your timeline you will see that one option is “play base layer only.” Try it…
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Sascha Engel
    February 16, 2011 at 6:22 pm
    Thanx David, but I also know that one.
    In my specific case it just didn’t help, since I had in the V2 layer a slug Line with Widescreen bars in it, which I did wanna see – to do the right framing.
    Just the effects should have been off.
    It’s those little things that bother me sometimes about FCP workflow – that and a proper masking system and proper audio key frames 😉
    Any idea possiblity to achieve that?
    Sascha
  • Peter Wiggins
    February 16, 2011 at 7:37 pm
    Nothing wrong with the audio keyframes – just use automation
    Peter
  • Sascha Engel
    February 16, 2011 at 7:49 pm
    Very good point – never tried it that way, cause the keyframes put manualkly suck.
    By the way – is there any way, I can connect my Oxygen 8 or Akai Midi Controller to connect to FCP?
    Sascha
  • Sascha Engel
    February 17, 2011 at 4:04 pm
    I tried the automation, but it still gives me this hideous curve just before it hits the silence – there’s no way to fade down linear in FCP and it’s really a pity.
    Sascha
  • John Pale
    February 17, 2011 at 6:56 pm
    [Sascha Engel] “t’s those little things that bother me sometimes about FCP workflow – that and a proper masking system and proper audio key frames ;-)”
    For motion graphics you have Motion. You can turn things on and off there (and a whole lot more)
    For fine audio work you have Soundtrack Pro. (several different types of audio fades exist there)
    Final Cut Studio is a suite of programs, and for better or worse, is intended to be used as such. I don’t believe any other NLE has what you are looking for either (Maybe Vegas, on the audio issue)
