Activity › Forums › Apple Final Cut Pro Legacy › De noising and Sharpen Question
  • De noising and Sharpen Question
    Posted by Ronnie Gilmer on January 6, 2014 at 1:39 pm
    Hello, I was searching for a noise reduction plugin and came across “Neat Video” i downloaded it and applied it to the clips in the timeline but I couldnt see a before and after difference. The same goes for the sharpen effect/plugin that I dragged onto the clips on my timeline. Could I not be seeing the difference because of my GPU?
    Ronnie Gilmer replied 12 years, 8 months ago 3 Members · 3 Replies
  • Mark Suszko
    January 6, 2014 at 4:57 pm
    You may need to adjust some controls in the plug-in and then render, before you see an effect.
    I’m always curious about how good this plug-in works, so if you can post some before and after shots, I’d appreciate it.
  • Joe Barta iv
    January 6, 2014 at 7:01 pm
    Select OPTIONS in the neatVideo plug-in. That will open up the program. Then select Auto-Profile, then OK. Then you should see a difference back in FCP when you switch it on and off.
    https://www.neatvideo.com/files3/NVFCMQSG.pdf
    Bars & Tone
    SALUTE!
  • Ronnie Gilmer
    January 6, 2014 at 11:33 pm
    Hey thanks and here is confirmation the plug in does work if you look to the right of the girl in the brown area you can see the difference also on the left side and areas in her face.
    Before
    After
