Activity Forums Adobe After Effects De-materialisation plug-in!!
  • De-materialisation plug-in!!
    Posted by Rikshore on October 4, 2005 at 12:55 pm
    Hello there,
    I am new to writing a post in this forum but have read quality responses and threads for a long time so here i am.
    I am looking for a plug-in to help me create an effect that i saw in a Bouygues telecom advertisement here in Paris recently. The ad sees people and objects “dissolve” or de-materialise into cubes that then float away en masse.
    I have started a job for a new hotel that is called “Cube” so it is perfect for what i want to do.
    I would greatly appreciate anyone help on this to find the plug-in which i have heard exists somewhere.
    Thankyou.
    Go to ;
    https://www.stylewar.com/main.html
    Then >Commercials>Bouygues>Quicktime to see the original ad.
    Rikshore replied 20 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • Jeff Dobrow
    October 4, 2005 at 1:19 pm
    Hmmm….it sounds as if this effect involves disintegrating into ‘3d cubes’.
    I am not sure of any plugs that would do ‘exactly’ that……I would personally do it in a 3D app, then composite in AE.
    Good luck,….hopefully someone else knows of such a plug……..
  • Mstleger
    October 4, 2005 at 2:11 pm
    Hey, I’m working on a Bouygues commercial right now. We’re using a similar effect with the cubes, alot of the work is done in 3d. No simple solution, just plan to have a clean plate of the footage, and get someone to run dynamic simulations in 3d. Also, if the camera is moving, you’ll need to do some 3d tracking.
  • Spockedit
    October 5, 2005 at 3:09 am
    I took a look at the commercial. Very cool. You’d have to do more than run a particle simulation. You’d have to actually create a 3d model of whatever it was you want to dematerialize and then composite it.
    Censored by Admin
  • Saudi
    October 5, 2005 at 2:46 pm
    Just for inspiration purposes. Check out this Particle Issusion Tutorial from Elvis Deane. Maybe u can get an idea of how to fake the 3D Simulation by using 3D-Qubes as particles. It will not look as good ( exact) as the commercial. I also dont think that there is a special plugin for this kind of effect.
    https://www.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=23&page=/articles/deane_elvis/disintegratePeople/index.html
    Greez and if u get what u want post your solution
    Martin
  • Michael Szalapski
    October 7, 2005 at 2:34 am
    I don’t have time (or a terribly fast connection at the moment) to look at the add, but if you tweaked with some settings in Effect-Simulation-Shatter you might get something that’s workable for your usage.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Rikshore
    October 12, 2005 at 4:32 pm
    Thanks very much for all your responses. i have found the trapcode plug-in “particular” which is as good as all my other plugins put together. I used the custom setting and made my own box which turns and i know have as many little cubes racing around the screen as i wish and dissolving where i want.
    Cheers!
  • Rikshore
    Please see my last posting….
  • Rikshore
    October 12, 2005 at 4:33 pm
