Activity Forums Apple Final Cut Pro Legacy De-lacing plug-in for FCP version 7
  • De-lacing plug-in for FCP version 7
    Posted by Sheree Day on January 14, 2012 at 9:55 am
    HI
    Does anyone know of where I can download a de-lacing plug-in for FCP version 7 – I need a de-lacing plug-in that has interpolation.
    I’ve used the de-lacing in FCP, but I’ve heard there are better ones that do interpolation.
    Thanks.
    Sheree Day replied 14 years, 8 months ago 4 Members · 4 Replies
  • Rafael Amador
    January 14, 2012 at 1:10 pm
    If you are talking about “de-interlacing”, you have FieldsKit and Nattress for FC.
    There is also an standalone free application called “Jes deinterlacer”.
    Compressor has also very good deinterlacing options.
    rafael
    http://www.nagavideo.com
  • Ben Holmes
    January 14, 2012 at 3:02 pm
    Most of the ‘smart’ deinterlacers do this by using motion detection to retain information that would be common between fields – in this way, they try to keep the vertical resolution up whilst having a progressive look.
    The problem is that they can cause atifacting when they get confused, which is often more distracting that a straight de-interlace. Whatever you do to interlaced material, it will not be progressive when you finish (unless the camera shot PsF) – you can’t fake it entirely.
    When you talk about ‘interpolation’ you usually mean the opposite of this process – you are creating extra fields or frames from material, such as when you use optical flow, or 4-field interpolation for smoother slo mo. With a de-interlace, you are trying to take away fields, and this is trickier, as the image moves between them – it’s impossible to just double these up to make a single frame without guessing at the motion.
    Apart from graphics and small text, de-interlacing holds up much better in HD than it used to in SD material. For this reason, since moving to HD entirely, I bother a lot less now with ‘smart’ deinterlacers.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
  • Bret Williams
    January 15, 2012 at 12:57 am
    Why not work in interlaced, and then run the final product through compressor or AE to create the progressive final? Keep everything high quality as long as possible.
  • Sheree Day
    January 15, 2012 at 4:00 am
    HI
    Thanks for all the suggestions.
    I’ve only just learnt FCP and Motion. Haven’t got to After Effects (that will be a fair while down the track – I’ve heard it’s hard to learn), and not sure if I have compressor (don’t think it came in the package).
