Activity Forums Adobe After Effects De Interlace to match Premiere
  • De Interlace to match Premiere
    Posted by Paul Kozinski on March 20, 2014 at 11:54 am
    Hi chaps,
    I’ve deinterlaced all my footage in PREMIERE PRO CC using Field Options>Always DeInterlace, but there are a few clips in my timeline that are After Effects CC Comps.
    I’ve went into the comps and added the Reduce Interlace Flicker effect to the video – but does anyone know what I should set the softness to to match the deinterlace level in Premiere?
    Chris Wright replied 12 years, 5 months ago 2 Members · 3 Replies
  • Chris Wright
    March 21, 2014 at 1:25 pm
    Reduce Interlace Flicker just blur small details, doesn’t deinterlace.
    you render out AE with fields off to deinterlace. and make sure that interpret fields for video is uppper/lower/pulldown correctly first.
    if you want higher quality, I recommend plugins that preserver detail better than the default adobe settings.
  • Paul Kozinski
    March 24, 2014 at 9:24 am
    Brillian – thank you, I’ll give that a go 🙂
  • Chris Wright
    March 24, 2014 at 10:37 pm
    also in AE, if you select preserve details,the deinterlace may look better
