  • Posted by Mary Ann mcclure on February 26, 2008 at 2:42 am
    Hello Helpful ones,
    I am the unfortunate recipient of some footage that was shot on a DCR-DVD108 camera. I was handed a pile of discs and wondered if these at all could be imported into FCP for editing purposes.I have the camera as well. Do I need to dub them to tape first and import. It has a USB port and it’s own sony software. The book says it saves as mpeg2. Like we needed another media format. Sheesh! Any suggestions or am I sunk?
    M
    Rennie Klymyk replied 18 years, 7 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    February 27, 2008 at 2:20 pm
    https://www.apple.com/downloads/macosx/video/mpegstreamclip.html
    Will fix you right up!
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Rennie Klymyk
    February 27, 2008 at 7:08 pm
    Hope you are making out ok with your mpegs. You may find if the discs have been finalized they will mount in your computer, otherwise they will only play from the camera.
    I just completed some work from a Sony JCR-SR100 HDD camera that records mpeg2 to a HDD. I was able to import all the files to the desktop through USB. I used Streamclip 1.9.1 to convert them to DVCPRO50 but it was terrible. There was a luminance shift after every cut (from the original camera) and pans, tilts and any fast motion created jumps. I tried to stitch all the original clips in streamclip and burn a dvd but toast wouldn’t burn the file after only just repairing the tc breaks. Finally, since the camera played back everything well, rather than continuing to experiment I recorded the program onto a dsr11 through the composite out of the camera and got satisfactory results.
    Streamclip has been very useful in the past but not this time. Sometimes the old “tape” to “tape” is still the best.
    “everything is broken” ……Bob Dylan
