Activity › Forums › Adobe Premiere Pro › dcp @ 1:66
  • dcp @ 1:66
    Posted by Saul Emilio on January 27, 2017 at 2:55 pm
    Hello,
    I’m editing a film based on still photographs in 4K at a 1:66 ratio. My timeline is at 4096 x 2458 (square pixels). I’ve just learned that I’ll need to provide a cinema DCP as the output. I’ve googled around and found some common formats for 4K DCP, the least wide of them being QuadHD 16:9 which is 1:77. I’ve never exported to DCP before and I’d like to know if it’s a flexible format which would accept a 1:66 timeline or if I’m looking for trouble and should switch to 1:77 instead.
    Thanks a lot.
    P.S. Creative Cow webmaster : writing “dcp” correctly shouldn’t be detected as being all-caps… 🙂
    Saul Emilio replied 9 years, 8 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    January 27, 2017 at 4:18 pm
    The specced flat (1.85:1) resolution for 4K DCPs is 3996×2160. You’ll have to either crop it or scale it to fill that resolution. UHD 3840×2160 is not in the DCI specification but it is DCI compliant.
  • Saul Emilio
    January 29, 2017 at 7:37 pm
    Thank you. I’m not sure I understand the difference between being compliant and being in the specs. Do you mean that the resolutions listed here are not necessarily supported by all projectors?
    EDIT: By “here” I mean this: https://blog.chameleondg.com/post/111891072017/resolution-aspect-ratio-cheat-sheet
