DBFS too low?
Posted by Daniel Stone on July 28, 2014 at 6:52 pmWe’ve been uploading our spots with an audio level of -24 LKFS. A spot just got rejected because, though it’s at -24 LKFS, it’s at -35 DBFS.
How do I fix something like this? If I raise the volume, won’t my LKFS go up, too?
Thanks of any help.
Daniel Stone replied 12 years, 1 month ago 2 Members · 8 Replies -
Eric Toline
July 28, 2014 at 7:33 pmIt seems you’re mixes are a bit too low. See attached quote.
“Meanwhile, the target loudness is, simply, –24 LKFS for the anchor element. Given such a target, I would expect to see levels of up to –16 LKFS (maybe even higher) for the entire mixed program. It’s unclear, unless you have the meter and the post-production time to do all the measurements and corrections. More importantly, there is potential for error to creep in at any point in the broadcast. We need to ensure that the original signal is at an appropriate LKFS level (approximately –16 to –20 LKFS for a –24 LKFS anchor element level). We then need to maintain that level at approximately unity gain throughout signal distribution and transmission.
– See more at: https://www.tvtechnology.com/inside-audio/0176/lkfs-amp-the-calm-act/208806#sthash.hDg2Jfg5.dpuf”“I push the RECORD button and hope for the best”
Daniel Stone
July 28, 2014 at 8:49 pmThanks so much, Eric. Great article.
This might seem like a stupid question but how do I measure average dBFS?
Eric Toline
July 28, 2014 at 9:22 pmMeasure it on what piece of equipment with what metering at what voltage? You have to calibrate your playback unit with a known source level to know where to put your reference point. A long, long time ago in another era we used professionally made calibrated alignment tapes…..but things were much simpler then.
Daniel Stone
July 28, 2014 at 9:42 pmI see. More difficult than I thought.
Forgive me if I sound like a 10 year old, here, but I very much appreciate your help:
Our spot got rejected because the “Average dBFS” was too low (-33 db). Yet, the LKFS average was -24 LKFS (as measured by Premiere’s Loudness Radar). I only have +/- 2 LKFS of room before the spot gets rejected for that. So, how do I raise the Average dBFS without raising the LKFS? Because once I hit -21.9 LKFS, my spot gets rejected.
Eric Toline
July 29, 2014 at 2:00 amAre you using any compression or limiting on the final mix?
Daniel Stone
July 29, 2014 at 11:47 amI’m using a tiny bit of compression on the final. Just enough to level the VO a bit.
Do you think bringing up the level of the non-VO parts with compression and limiting is the solution?
Eric Toline
July 29, 2014 at 12:21 pmAnything you do with compression & peak limiting on the non VO parts is going to help. Try it, you have nothing to lose and everything to gain. (pardon the pun)
