Activity › Forums › Cinematography › daylight 16mm film stock – load
Posted by Vlady7 on February 9, 2006 at 4:19 amHello,
I’ve just bought colour negative 16mm Kodak film, one side perforated, 100f sealed in Kodak box. But there is info that it should be loaded in total darkness. Can I use special bag to put the film into my Bolex? Can I use splicer to add black leader? However, some film stock is packed in a way that you can load in daylight – what is the difference? I would be grateful for explanation.
best regards
vladyTodd Mcmullen replied 20 years, 7 months ago 3 Members · 6 Replies -
Blub06
February 9, 2006 at 5:31 amI have never heard of a 100 foot load not coming on a metal reel which allows for daylight loading. I guess you could turn the lights off at night, cover your hands and the box with something and open the box and feel if there is a metal reel with this film.
What you are talking about is called a changing bag.
I would NEVER put a splice through a camera, there are real chances that the glue or tape that you use to splice will rub off on the gate and smear the film or break or the leader might not even fit the camera. Camera original film and print film including leader are of different dimensions especially the sprocket dimensions. This could lead to mechanical issues.
Chris
Todd Mcmullen
February 10, 2006 at 2:32 pmYeah daylight loads,hmmm, I was known as eyemo boy in my early days as a camera assistant. I was fast at changing the 100ft daylight loads in eyemo cameras for stunt work.
Just keep the roll as tight as you can when loading, avoid direct sunlight, maybe a bit of black over you and the camera if in desert or other bright areas.
Make sure your hands are dry, not sweaty, and roll off a couple of seconds before. You should be ok. don’t ever add leader though. They do that in processing.
Good luck.Todd McMullen
Flip Flop Films
Austin
Cinematography Forum Leader -
Todd Mcmullen
February 10, 2006 at 2:33 pmYeah daylight loads,hmmm, I was known as eyemo boy in my early days as a camera assistant. I was fast at changing the 100ft daylight loads in eyemo cameras for stunt work.
Flip Flop Films
Austin
Todd Mcmullen
February 10, 2006 at 2:40 pmYeah daylight loads,hmmm, I was known as eyemo boy in my early days as a camera assistant. I was fast at changing the 100ft daylight loads in eyemo cameras for stunt work.
Flip Flop Films
Austin
Todd Mcmullen
February 10, 2006 at 2:44 pmthe bag said decaf…
Todd McMullen
Flip Flop Films
Austin
