Activity Forums Adobe Photoshop day into night
  • day into night
    Posted by Maxim Moisseev on August 2, 2008 at 5:38 pm
    Can you give me a clue how to make a summer day shot into winter night shot in PS?
    Some tips or tutorial maybe. IMG_4507
    I have experience in PS, but this task seems difficult.
    Darby Edelen replied 18 years, 1 month ago 2 Members · 4 Replies
  • Maxim Moisseev
    August 2, 2008 at 9:33 pm
    thanx, I’ve almost done it. See what it looks like.
    If you have remarks, please, post it here.
     dvorzovi
  • Darby Edelen
    August 6, 2008 at 5:55 am
    That’s looking like a pretty good start. You’ve reduced the saturation, darkened the image, and added a blue tint which are all good things.
    I would say the remaining issues would be the light sources that you would expect to be ‘on’ at night time have been darkened as well, and your water looks very different (is that the same water from the original shot?). I would expect to still see shadows/reflections in the water.
    It’s usually easier to get good results with day for night using source material that was shot at dusk or in overcast conditions without such strong directional lighting (from the sun in this case).
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Maxim Moisseev
    August 6, 2008 at 6:06 am
    Thanks, Darby!
    Water is different, ’cause it’s frozen. You’re right. It’s intended to be a winter shot.
    I also see a problem with strong direct sunlight, but this is the only way to make a shot – in the evening, they turn bridge illumination on, and I don’t need the bridge to be illuminated. So i thought it would be easier to dissimulate ambient light than to retouch hundreds of light bulbs.
  • Darby Edelen
    August 7, 2008 at 6:15 pm
    [Max Moses] “I also see a problem with strong direct sunlight, but this is the only way to make a shot – in the evening, they turn bridge illumination on, and I don’t need the bridge to be illuminated. So i thought it would be easier to dissimulate ambient light than to retouch hundreds of light bulbs.”
    Good call, it all depends on what look you’re going for. I was wrong to assume that you’d want the light bulbs on.
    [Max Moses] “Water is different, ’cause it’s frozen. You’re right. It’s intended to be a winter shot.”
    I think shadows on the frozen water still might help. You should be able to create shadows using the original image. Try duplicating the blue channel, inverting it, playing with levels and painting out the areas you don’t want to be shadowed (basically everywhere but under the bridge). That should give you a good base for a layer mask on a ‘shadow’ layer. Here’s one I put together quickly from the images you posted:
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
