DAW for use with Pro Tools?
Posted by Courtney Marietta on July 12, 2009 at 9:10 pmI am in search of a DAW to use with Pro Tools, but I only have about $350 to spend, so any of the official Digi worksurfaces are out. Can someone please suggest an alternative?
Thank you.
Scott Koué replied 17 years, 2 months ago 5 Members · 7 Replies -
Steven Talley
July 12, 2009 at 9:58 pmDo you have Firewire 400 on your computer? If so, it’s better then USB.
Courtney Marietta
July 12, 2009 at 10:45 pmI have Firewire 800. And I’d love to be able to connect using that.
Sam Mallery
July 13, 2009 at 1:07 pmTerminology-wise, you need to sort some things out.
DAW refers to the software being used. In your case, the DAW is Pro Tools, because Pro Tools is software.
What you need is an audio interface that’s compatible with Pro Tools, and you need the DAW software as well. There are two ways to go. You can either get a Digidesign hardware/software bundle, or you can buy M-Audio M-Powered Pro Tools software, and compatible M-Audio hardware.
If you want to use your FireWire port, you could buy the M-Powered software for $245:
https://www.bhphotovideo.com/c/product/594505-REG/M_Audio_9910_59817_00_Pro_Tools_M_Powered_8.html
And you would also need to buy M-Audio hardware. This is the cheapest FireWire option:
https://www.bhphotovideo.com/c/product/353766-REG/M_Audio_9900_50739_00_FireWire_Solo.html
That would put you at $425. Considering that the cheapest Digidesign option is the M-Box 2 Pro at $599, going the M-Powered + M-Audio route isn’t a bad option. You would just need a FireWire 400 to 800 cable and you would be set.
Courtney Marietta
July 13, 2009 at 4:01 pmI apologize for using the wrong terminology. Let me clarify:
I currently have Pro Tools LE with DV toolkit on my computer. I use the MBox Micro. I’m looking for a compatible digital worksurface (like the 002, 003 or Command 8) but I can’t afford those options. I’m looking for other suggestions.
Sam Mallery
July 14, 2009 at 6:11 pmOkay. Ignore my first suggestion. You already have an interface, and the DV Toolkit isn’t compatible with M-Powered Pro Tools.
You just need a MIDI control surface. FOr a little less than a Control 8 you can get a Euphonix MC Mix:
https://www.bhphotovideo.com/c/product/555488-REG/Euphonix_947_10279_01_MC_Mix_Control.html#features
On the cheap you could get a Frontier Tranzport (wireless, but no faders):
There’s the Faderport from Presonus with one motorized fader that you cna use to control all of the faders:
You will likely be fine with this really affordable controller from Korg, the nanoKontrol:
The nanoKontrol works with Pro Tools. Just be prepared for a little set-up time/getting-to-know-you learning curve with any of these devices. They’re usually not as plug-and-play as you want them to be.
Peter Groom
July 15, 2009 at 9:34 amHi Sam
Any of those surface controllers work with avid Xpress that you know about?
PeterPeter
Scott Koué
July 15, 2009 at 8:36 pmI think you must be referring to an interface. ProTools IS a DAW. Which brings up the question of what version of PT you have and/or where you got it. PT mostly comes with matching hardware. If it’s not the “M-Powered” version you can only use it with Digi’s hardware, and your not going to find much in your budget range. The M-Powered version requires hardware from M-Audio, so look at their boxes.
