Activity Forums DaVinci Resolve Davinci+Filmconvert: Single bright frames on export
  • Davinci+Filmconvert: Single bright frames on export
    Posted by Timm-christian Schindel on June 1, 2015 at 9:19 am
    i have a documentary of 30 minutes length exported from PR to DaVinci, to apply my FilmConvert plugin to it. The Footage is ProRes 1080p25 and I used the Final Cut Pro XML export in PR to get everything into to DaVinci. All project data is stored on an USB 3 drive. The importing worked fine and FilmConvert did it’s thing beautifully. However, when working through the shots i recognised, that when i clicked on one, that had the effect already on it, it took half a second to display the correct result. Meaning, that often the image was brighter at first and then it switched to how it was supposed to look. I didn’t care about it, as it didn’t effect my workflow much. But later, when I went over to rendering, these flashes came up in the final result. Always only one slightly brighter Frame at the beginning of some of the shots.
    At first i exported ProRes as single clip, then i tried individual clips, after that TIFF, then again ProRes to my internal SSD to check, if it’s somehow related to the USB 3 drive. I also cranked down the render frame rate to 2f/s. Nothing helped.
    I’m deep into Adobe but I’m not much of a DaVinci professional (yet). So perhaps it’s some simple tweak. I don’t know.
    Appreciate your help.
    Timm
    OS X YOSEMITE (10.10.3)
    Mac Pro (Late 2013)
    Prozessor 3,7 GHz Quad-Core Intel Xeon E5
    Memory 32 GB 1866 MHz DDR3 ECC
    Graphics 2x AMD FirePro D300 1024 MB
    Adobe Creative Cloud 2.0.0.74
    – Premiere Pro CC 8.2.0
    – After Effects CC 13.2
    Davinci Resolve Lite 11.3.0lite.004
    – Plugin: FilmConvert Pro 2.0
    Canon EOS 600D
    – Walimex Pro 24mm 1.4
    – Magic Lantern 2.3.600D.102
    – Technicolor CineStyle
    granarte.com
    Marc Wielage replied 11 years, 3 months ago 3 Members · 2 Replies
  • Andi Winter
    June 1, 2015 at 10:00 pm
    you could try to force filmgrain using the cpu only and see if that solves your issue.
  • Marc Wielage
    June 4, 2015 at 4:18 am
    Sounds to me like the OFX plug-in is getting delayed when the frame boundary is hit. I would contact Film Convert and yell at them — this may not be a Resolve issue per se. There might be a way for them to provide an overall setting that could dial in the “frame early/frame late” number to get it correct.
    I have seen other OFX plug-ins behave badly with keyframes as well, forcing me to start them earlier or later than expected in order to get the desired results. I haven’t seen them totally miss a frame… yet.
