Activity › Forums › DaVinci Resolve › Davinci workflow question… Can timeline be used as a clip to conform to?
  • Davinci workflow question… Can timeline be used as a clip to conform to?
    Posted by Ronnie Shatto on January 12, 2015 at 10:53 pm
    Hello everybody,
    My basic question is can a timeline in Davinci be used like a raw file and conformed with?
    Here is my workflow…
    We shot a round table discussion over the course of a day. The cameras we used were 5 canon xf305s, a sony ex1 and a 5d mark ii. The canons record in small continuos files. (This might’ve been my first mistake) when I bought them in the different sections of the interview were split over different cards and folders. What lined up in one camera would be in a different folder on another camera. Also every folder I was given (a folder with all a cam, b folder with back) had similarly named clips. They were all AA0001, AA0002, etc. Not sure if a professional dit would’ve offloaded cards differently or what or if the cards should be offloaded at every break. I had to build strings so I could multicam the interviews properly. I ended up with 7 sequences for each part of the discussion. I Exported each timeline with a starting time code that matched the first clip in that sequence and I added time code for the dslr. I got everything into the avid and it worked perfectly.
    Now onto my question. My intentions were to reexport mxf strings to replace the dnx36. I work this way usually but on smaller scale projects and after exporting 40 hours of footage I’m not too interested in doing that again. At the very least I know this will work but I want to hopefully get a workflow that will relink the offline cuts to the timelines I made in Resolve with the raw camera media.
    Thanks in advance!
    Ronnie Shatto replied 11 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
