Activity › Forums › Boris FX Particle Illusion › daVinci style pain stroke
Posted by Andres on September 12, 2006 at 7:16 pmI need to create a “davinci style” paint stroke which will be reveling an object. Do you PI experts think i should tackle this in Particle Illustion or should I look for a different solution?
Andres replied 19 years, 11 months ago 3 Members · 4 Replies -
Alan Lorence
September 12, 2006 at 8:02 pmI’m not sure what you mean by this. Can you give an example, or better explanation?
You can use some of the emitters to do a “brushstroke” type effect, but it may not be what you want.
Alan.
wondertouch -
Andres
September 12, 2006 at 8:37 pmI dont have a specific example per say. What i had in mind is like u said a simple brushstroke which would reveal a high-rise building. I looked through all the emitters but found none. I’m I overlooking one? What Library do u recommend for “brushstrokes”?
thanks in advanced
Elvis Deane
September 12, 2006 at 11:36 pmIs this the sort of thing you mean? You have to manually animate the stroke thickness, which can be done in the Size graph.
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Andres
September 13, 2006 at 2:32 amThanks for the file. but not quite. Maybe its just my lack of knowledge of the program. What i had in mind was a more fluid brush stroke like this: almost like a quick sketch – see link
https://www.d-work.us/temp/brushstroke.jpg
