Activity Forums DaVinci Resolve DaVinci Stability Decreasing – Freezing UP
  • DaVinci Stability Decreasing – Freezing UP
    Posted by Craig Harris on April 21, 2011 at 1:20 am
    Is there anyway to give Resolve a good old fashioned cleaning? There are some old projects that I’d like to delete but can’t. I get the spinning wheel for 4-6 minutes and when it stops spinning, the projects are still there. Also, project are beginning to freeze from time to time which forces me to force quit the application. Not a big deal, but that seems to be killing performance when I attempt to re-open those projects.
    Any thoughts?
    Craig
    Colorist – Vancouver
    Sascha Haber replied 15 years, 4 months ago 3 Members · 3 Replies
  • Rohit Gupta
    April 21, 2011 at 2:01 am
    Hi Craig,
    In the DB Manager on the login page, you can create a new database, and it is pretty much a clean start. You should be able to switch back and forth to the old databases if required, or copy projects from the old database to the new.
    We are working on some optimizations for the delete project performance, and it will show up in v8.
    Regards,
    Rohit
  • Craig Harris
    April 26, 2011 at 1:29 am
    Thank you Rohit!
    I am having a reoccurring problem with a couple of projects containing Pro Res files. When I try to save the projects, the progress bar often gets to %54 and then freezes. Any suggestions?
    Kindly,
    Craig Harris
  • Sascha Haber
    May 18, 2011 at 9:33 am
    Lets it run…it will come back.
    We have exactly the same problems in a huge feature film database.
    If you need to speed it up right make a new Database per Project.
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
