Activity Forums DaVinci Resolve Davinci runs slow
  • Davinci runs slow
    Posted by Rick Van den berg on March 4, 2013 at 11:08 am
    I got a bit of a problem here. when i start a project, it seems it works okay (still not fast/realtime), but when i get closer to the end (mostly 3 min’s music video’s) its getting slower and slower. i understand its pretty much impossible to play RED files realtime with color correction, masks, keys and so on, but when i tweak something like only the color wheel, it updates maybe after 3/5 seconds or sometimes even longer. very annoying. i just cant work like that. Im running on a mac 2x 2.8 ghz quadcore, 16 GB DDR2 with a RED ROCKET card installed.
    I tried to clean up the whole mac, updated the rocket firmware, but no noticeable effect.
    i know it can never go realtime with very complex shots(at least not with this system), but im sure it shouldnt go this slow.
    any idea’s?
    thanks in advance
    Erline O’donovan replied 12 years, 10 months ago 10 Members · 16 Replies
  • 16 Replies
  • Pepijn Klijs
    March 4, 2013 at 5:23 pm
    What other graphic cards you have installed? Have you tried lowering the debayer quality?
    Editor/Colorist, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
  • Rick Van den berg
    March 5, 2013 at 8:20 am
    i have an ATI Radeon HD 5770. i must say i didnt think about lowering the debayer quality. i will try that later today. thanks.
  • Dan Moran
    March 5, 2013 at 9:25 am
    I think the ATI card might be your problem. Resolve is optimised for Nvidia CUDA cards and runs a hell of a lot faster on them. Not 100% sure but may be worth thinking about.
    Dan Moran
    Colourist
    Smoke & Mirrors: London
    http://www.danmorancolor.com/blog
  • Peter Chamberlain
    March 5, 2013 at 10:28 am
    That Ati card is good for UI, not image processing. Please refer to the config guides on our support web site for details of supported configs.
    Peter
  • John Tissavary
    March 5, 2013 at 9:03 pm
    Your graphics card is insufficient for Resolve. Check the configuration docs on the bmd website, but you will need an Nvidia card, not an ATI for starters. I’m not sure what fits in a macpro without expansion chassis, but I do know you can get an Nvidia GTX 570 in there and it will perform ok, much better than what you have. I think you can get a GTX 680 in, but someone else who’s done it will have to confirm.
    Also make sure you have ‘use optimized playback’ enabled in settings.
    JT
    John Tissavary | colorist | owner
    The Post Collective
  • Jake Blackstone
    March 5, 2013 at 10:51 pm
    Speaking of ‘use optimized playback’. Can someone tell me why anyone would want an un-optimized playback?
  • Juan Salvo
    March 5, 2013 at 11:01 pm
    There is a weird thing with Cacheing that happens in optimized mode. Optimized, not so optimized for render cache.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Rohit Gupta
    March 5, 2013 at 11:44 pm
    Hi Jake,
    You lose your window cursors, etc on the SDI in this mode. Only during playback.
    Regards,
    Rohit
  • Jake Blackstone
    March 6, 2013 at 1:24 am
    Does anyone uses caching on Resolve? I can’t imagine anyone suffering though that…
  • Jake Blackstone
    March 6, 2013 at 1:29 am
    I see, thanks for the clarification Rohit. I don’t see that as a problem, as personally, I never use cursors on the video display. Clients always complain about it. BTW, did the shortcut Shift/Cmd/C for turning the windows on/off on the video output had been taken out? I remember it used to work before, but at some point it stopped and now it is necessary to chose it from the menu.
