Activity › Forums › DaVinci Resolve › Davinci RUNNING OUT OF MEMORY??
Chris Jacobson replied 14 years, 10 months ago 8 Members · 19 Replies
Gareth Cook
November 11, 2011 at 3:44 pmHey Chris, how ya been? I have yet to experience this but when we had Resolve years ago at Encore I believe this message popped up when the storage for the still store was getting full. Peter is this a possibly reason for Chris’s memory message.
Gareth
Severin Schultze
November 11, 2011 at 3:46 pmDid you try to pull one of the 4000s? Using just one card seems to work here- at least Resolve is running quite well for the last couple of hours without any crashes or error messages. I’m in touch with the support to further investigate…
DIT @ WeFadeToGrey
Chris Jacobson
November 11, 2011 at 4:25 pmSeveren- I know the problem your having. The reason it works better with one card is a 5d codec problem. with 2 graphics cards the davinci/cuda doesn’t know how to divide up the media/frame causing it to get stuck and/or crash. In the past we transcoded all 5d media and the problem was solved. The latest version of software and firmware updates should do the trick too.
Chris Jacobson
November 11, 2011 at 4:28 pmHey Gareth,
Things are great. Working on the westside coloring and producing movies and TV shows.
I don’t think it’s a storage issue because I’m using a partition on our SAN as my “local” for stills and cached media…but I’ll check it out.
Margus Voll
November 12, 2011 at 8:47 amtranscoding this 5000 pixel stuff to something else seems also reasonable idea if this resolution is not needed in the workflow later. Specially animation format as it is not supported as far as i know ?
I would even bet that you should try to swap 4000 cards when you have just one in the machine.
Some people have had problems with faulty cards.
Specially on 4000 series.—
Margus
Sascha Haber
November 12, 2011 at 7:13 pmTime to go 64 bit, Resolve.
A slice of color…
DaVinci 8.0.1 OSX 10.7
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 470 / GT 120
Extreme 3D+ WAVE -
Chris Jacobson
November 15, 2011 at 12:33 amdefinitely not a storage issue. I have 3 tbs on local available
Chris Jacobson
November 15, 2011 at 12:41 amcould be a possible memory leak on the MAC…investigating
