Activity Forums DaVinci Resolve DaVinci Resolve with Single GPU – Recommendations?
  • DaVinci Resolve with Single GPU – Recommendations?
    Posted by James Wong on November 18, 2011 at 10:54 pm
    Using DaVinci Resolve currently gives me (expectedly) subpar performance because I don’t have a second GPU/video card installed to do the heavy lifting.
    Here are the system specs:
    Mac Pro 5,1
    OS X Lion 10.7.2
    24GB of RAM
    Slot 1: ATI Radeon HD 5770
    Slot 2: RED Rocket Card
    Slot 3: Empty (houses the back ports that complement the RED Rocket card, however)
    Slot 4: RAID Card
    That said, I’ve only got room to replace the card in Slot 1 only
    (PCI extender is out of the question right now)
    The goal is to be able to grade R3D Epic footage natively within resolve.
    My question is:
    1. Is there a video card that you can recommend that will work with both Resolve and Lion given this single slot/single GPU limitation that I have with our system config?
    Thank you in advance,
    James
    Elliott Balsley replied 13 years, 11 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    November 18, 2011 at 11:08 pm
    Hi James, please refer to the configuration guide on the bmd support web site. It lists the working configs.
    Peter
  • James Wong
    November 22, 2011 at 10:28 pm
    Thanks, Peter. I read the config guide prior, but I know I’m working with a less-than-optimal slot setup with the Mac Pro at work (and getting a PCI extender is most likely out of the question at this time). 🙂
  • Elliott Balsley
    October 13, 2012 at 7:23 pm
    You could put the Rocket in slot 3, and find a creative place for the BNC jacks. Then you could have 2 GPUs, and only lose a little speed from the x4 Rocket.
