Activity Forums DaVinci Resolve DaVinci Resolve Render with Reel ID
  • DaVinci Resolve Render with Reel ID
    Posted by Sean Connolly on October 12, 2010 at 5:17 pm
    Hello,
    I am working on DaVinci Resolve 7.0.2 Mac version. I am trying to render files from DaVinci resolve and have the resulting exported files maintain both their source timecode and Source ID or Reel ID. When I select a sequence and select target as Source it does indeed render each clip individually and maintain the source timecode, however the reel ID is empty. When I check the clip info of individual clips in DaVinci I see that it does identify and display the correct Reel ID of the source file. Is there a way to maintain this information and embed it into the rendered file?
    I was rendering a source file Apple ProRes 444 to output Apple ProRes 422. The original file had an identifiable Reel ID embedded in the quicktime. The rendered file did not.
    Can anyone help me out on this?
    Sean
    Sean Connolly replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
