Activity Forums DaVinci Resolve Davinci Resolve Lite 8.2.1 Database Problems
  • Davinci Resolve Lite 8.2.1 Database Problems
    Posted by Krishan Bansal on May 20, 2012 at 4:50 pm
    Hello, I just installed Davinci Resolve Lite 8.2.1 on my mid 2011 iMac running Lion OSX 10.7.3. I am getting a no database error when I go to open reolve though and I cannot create a database. I have tried all the terminal commands and unistall and reinstall suggested by the other forums and I still am not able to create database and use resolve. PLEASE HELP ME I have been trying to fix this problem for weeks.
    Zel Nonnenberg replied 12 years, 3 months ago 4 Members · 3 Replies
  • Dan Moran
    May 22, 2012 at 8:50 am
    Hi Krishan,
    I believe you have an incomplete and/or corrupt Postgres database
    installation. When you install Resolve, it installs the Postgres
    database
    app, and automatically creates a database with the admin and user
    logins.
    Since you have no user login icons, something failed with the Postgres
    install. That’s why you can’t make a new database
    The usual fix for this is to rename the /Library/PostgreSQL folder and
    reinstall Resolve. Hopefully Postgres will then install properly. So,
    in
    Finder, rename /Library/PostgreSQL to /Library/PostgreSQL_bad, the
    reinstall
    the Resolve app, and login and hopefully you will have a guest and
    admin user login icon.
    If this does not work, let us know. There is a more extensive Postgres
    removal process we may have to go through to get it working.
    Dan
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Tom Keffer
    August 8, 2012 at 1:36 am
    DaVinci Resolve did work in OS X 10.5 and 10.6, but it is not working in 10.7.
    I have OS X 10.7.4, and I get the no database error when I start DaVinci Resolve. I have uninstalled both DaVinci and the PostgreSQL database, and reinstalled them, and that has not helped. I renamed the PostgreSQL database folder and reinstalled, still a no go on the database.
    Originally, it would not even start the database manually, but after a permissions repair I can get it to start by going into the applications/PostgreSQL 8.4 folder and either the Restart Server, or the Start Server application will get the server running. Once the server is running, I do see the proper accounts most of the time, but not always.
    Looking for the next steps.
    Here is a brief on the hardware:
    Model Name: Mac Pro
    Model Identifier: MacPro4,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.93 GHz
    Number of Processors: 1
    Total Number of Cores: 4
    L2 Cache (per Core): 256 KB
    L3 Cache: 8 MB
    Memory: 8 GB
    Processor Interconnect Speed: 4.8 GT/s
    Boot ROM Version: MP41.0081.B08
    SMC Version (system): 1.39f5
    SMC Version (processor tray): 1.39f5
  • Zel Nonnenberg
    June 7, 2014 at 9:06 pm
    Im having the same problem with Davinci Resolve 10, and none of the tricks solved my issue, so Im open for the full unnistall process of postgre SQL its urgent because of a work, thank u very very much!
