Activity Forums DaVinci Resolve Davinci resolve importing proxies xml even when unchecked
  • Davinci resolve importing proxies xml even when unchecked
    Posted by James Hark on December 24, 2016 at 9:32 pm
    So I import my CinemaDNG files to resolve, export proxies using fcpx setting, then export xml from fcpx, then when I import the xml it always brings the proxies in no matter what, and doesn’t link to the RAW files. also if I try to change the conform options, it gives me problems with linking because of the timecode extents not matching. If you could help me I would really appreciate it. thank you
    Problem fixed. when I first imported my clips into Davinci, the program added the [000000-0005432] frame count on the clip name in Davinci. but when exported it wasnt there so it wasnt matching the name.
    James Hark replied 9 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
