Activity › Forums › DaVinci Resolve › DaVinci Resolve for Mac Configuration Guide
Illya Laney
August 31, 2010 at 9:06 pmIf you’re desperate for space it looks like a cable could run directly to the HDMI slots in the back. Haha.
twitter.com/illyalaney
Motion Design, Color, Editing
SWGC Incorporated -
Arthur Puig
August 31, 2010 at 10:06 pmyou connect the fifth one where the second DVD drive should connect.
Vladimir Kucherov
August 31, 2010 at 10:10 pmExactly what I did actually. I used empty space on the plate of my raid controller to create a hole large enough for 1 HDMI cable. Works, even if it’s not exactly pretty!
Ola Haldor voll
August 31, 2010 at 10:36 pmIf just my 4-port eSATA RAID card had some space left.. 🙂
Vladimir Kucherov
August 31, 2010 at 11:14 pmYyeah, I mean there’s always the side of your mac pro but that’s almost TOO cruel!
If HDMI is a deal braker, one could always get an HDLink – at $470 it’s definitely affordable and gives you some more image calibration control which is always nice.
Mika Joon
August 31, 2010 at 11:27 pmI think I might need to drill a hole through the aluminum casing right in the middle of the apple logo to get the HDMI cables out to my monitor
Luke Maslen
September 1, 2010 at 12:33 amHi Aless,
The lower optical bay just has a regular SATA connection. So there are no special cables required and you can just plug in your SATA hard disk. Of course this is only worth considering if using an internal disk array. You wouldn’t bother using the lower optical bay for a hard disk if you were using an external disk array.
Regards,
Luke Maslen
Blackmagic Design -
Illya Laney
September 1, 2010 at 12:36 amFrankentosh?
SWGC Incorporated -
Luke Maslen
September 1, 2010 at 12:52 amHi Illya,
As others have correctly commented, the exclusion of HDMI is only because of limited slots in the Mac Pro chassis. The HDMI features of DeckLink work fine with Resolve on a Mac Pro but the HDMI bracket takes up a slot. This would mean either doing away with a HBA card or butchering the Mac Pro chassis which I don’t recommend you do! An SDI to HDMI converter can be used so you don’t take up a valuable slot internally. Of the Blackmagic Design converters, I’d recommend the HDLink Pro 3D as it is the most versatile model of HDLink. It accepts both single and dual-link HD-SDI, can connect to DisplayPort, DVI and HDMI monitors, has 3D LUT support and also works in 2D and 3D.
Regards,
Luke Maslen
Blackmagic Design -
Vladimir Kucherov
September 1, 2010 at 12:58 amDisguise the cable to look like a worm coming out of the apple and you’ve got one sweet casemod!
