Activity › Forums › DaVinci Resolve › davinci resolve exports only first clip
Posted by Clemens Krueger on September 19, 2012 at 9:14 amhi,
sorry for the stupid question…but i’ve a problem with rendering my timeline in davinci resolve lite 9. it always renders only the first clip of my timeline! how can i render the rest of the timeline??Laurie Little replied 12 years, 11 months ago 7 Members · 7 Replies -
Rohit Singhal
September 19, 2012 at 10:53 amOn the Deliver Page, Right click anywhere on the timeline just above the clip thumbnails (In case you already have a job in render queue, make sure its selected before this). Click “Select All”
Justin Lovell
September 23, 2012 at 2:12 pmshift click on all the clips in the render bin. they should all then have a green frame around them.
then hit render.
been there, done that… found a solution. 😉
Justin Lovell /Assoc. CSC
cinematographer//
8/16mm>2K.transfers
http://www.framediscreet.com -
Alex Robertson
January 14, 2013 at 7:54 amI am having the same problem and was relieved to find this page. however neither solution so far posted has worked for me, possibly due to some confusion on my behalf. I am also using resolve lite 9.
@Rohit – I presume you mean to click on the CTI bar just above the clips on deliver page? Then Edit >Select all? (There is no direct button with ‘Select all’ on my screen). However when I try this, nothing visibly happens, and when I render it still only exports the first clip.
@justin – Where do you mean by the ‘render bin’ please? I have tried shift clicking on all the clips in various places (deliver page timeline, colour page timeline, media page media pool, conform page media pool, etc) and none of these result in a green frame around the clips to indicate they are all selected. There is also no ‘Render’ button other than the ‘Render/Edit to Tape’ option buttons beneath the Deliver page video viewer. Do you mean ‘Start Render’? (This is what I have been using). Sorry to be so pedantic but I’m trying to get to the bottom of this annoying problem!
Thanks in advance
Colin Mcdsp
February 15, 2013 at 12:35 amI’m having the exact same issue and have not found a solution. Alex did you find what it was?
Laurie Little
October 27, 2013 at 10:17 pmHow do I change the name of my files in DaVinci 9 lite? getting a codec error and someone thinks file names may effect this.
