Activity Forums DaVinci Resolve DaVinci Resolve Database
  • DaVinci Resolve Database
    Posted by Yannick Haardt on May 2, 2012 at 6:46 pm
    Hey guys,
    I’m having a problem with Resolve. I can’t connect to the database or create a new one.
    Also I cannot connect to the database via PostgreSQL.
    I already tried this:
    – Reinstall Resolve
    – Manual Uninstallation:
    1) Stop the server
    sudo /sbin/SystemStarter stop postgresql-8.4
    2) Remove menu shortcuts:
    sudo rm -rf /Applications/PostgreSQL 8.4
    3) Remove the ini file
    sudo rm -rf /etc/postgres-reg.ini
    4) Removing Startup Items
    sudo rm -rf /Library/StartupItems/postgresql-8.4
    5) Remove the data and installed files
    sudo rm -rf /Library/PostgreSQL/8.4
    6) Delete the user postgres
    sudo dscl . delete /users/postgres
    Any suggestions?
    Cheers!
    Yannick
    Andreas Urra replied 13 years, 3 months ago 4 Members · 5 Replies
  • Juan Salvo
    May 2, 2012 at 7:02 pm
    Hi Yannick,
    Sorry to hear you’re having this issue. Was there an event that lead to this starting? Are you able to verify PostgreSQL is installed and running? Do you have a firewall enabled?
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Yannick Haardt
    May 3, 2012 at 9:27 am
    Hey Juan,
    thanks for your reply!
    PostgreSQL is installed – although when I try to connect to resolve database via pgAdmin III the server is not being found.
    Firewall is off.
  • Juan Salvo
    May 3, 2012 at 11:11 am
    You didn’t say what caused this to start?
    Can you try this manual uninstall procedure? Let us know if you get any error along the way.
    First run the davinci uninstaller.
    Then
    i) Stop the server.
    sudo launchctl unload /Library/LaunchDaemons/com.edb.launchd.postgresql-8.4.plist
    ii) Remove the plist file
    sudo rm -f /Library/LaunchDaemons/com.edb.launchd.postgresql-8.4.plist
    iii) Remove the Applications Menu.
    sudo rm -f “/Applications/PostgreSQL 8.4”
    iv) Remove the installation directory
    v) Remove the ‘postgres’ user
    sudo dscl . delete /Users/postgres
    vi) Remove the ini file
    sudo rm -f /etc/postgres-reg.ini
    Then rerun the davinci installer.
  • Gustavo Bernal-mancheno
    November 16, 2012 at 1:23 am
    Hi Juan,
    Sorry to budge like this here, but I need some help related to this:
    I was having issues with random flickers that occurred during my coloring sessions with Resolve. I found out through here that a solution may be upgrading to OS 10.8 upgrade. I followed it, and installed it, however, now I have another issue that is killing me: I opened resolve (9.03) and it now says that it’s unable to connect to the database – the list is blank.
    I tried uninstalling resolve, and installing it again -but same problem.
    So please, any advice on how to get my database connected WITHOUT loosing the projects that I have (and which I need to continue working on?) This is kind of urgent, and I’m sort of new with Resolve.
    Many thanks!
  • Andreas Urra
    May 10, 2013 at 6:48 pm
    Hi, although this thread may be dated, the issue is not. I ran into the same problem today. At first, I thought that nothing in the system had changed recently. However, as it turned out I had installed “Easy-hide-IP” some days ago and not touched DaVince since then. Although Easy-Hide-IP was not actually running I deinstalled it anyway. Luckily, this brought back my database in DaVinci.
    Even though this is quite specific, maybe if you experience the same problem it is worth looking into that direction.
    Good luck!
    Andreas
