Activity Forums DaVinci Resolve DaVinci Resolve 9.1 is now available
  • DaVinci Resolve 9.1 is now available
    Posted by Peter Chamberlain on January 18, 2013 at 6:06 am
    We are pleased to announce the release of DaVinci Resolve 9.1 with Retina Support which is available now on the BMD support web site. https://www.blackmagicdesign.com/support/
    This update is for our Mac, Windows and Linux customers at no charge. There are also new DaVinci Resolve Lite for Mac and Windows versions of 9.1 available now for download.
    What’s new in DaVinci Resolve 9.1
    • Mac OS X Retina support for MacBook Pro
    • Support for FCPX Audition in XML
    • Improved mixed frame rate XML support
    • Includes CinemaDNG Input Device Transform (IDT) for grading Raw images in ACES
    • Playback and render support for DNxHD 100
    • Playback support for XAVC and AVC-Intra100 MXF
    • Playback support for Sony Raw F55/F5 files
    • Faster rendering of Sony CineAlta SStP files
    • NTSC DV playback now supports 4×3 and 16×9 aspect ratios
    • Generation of new AAF for MXF audio renders
    • Support for timeline audio when PowerMastering
    • Chase audio offset can now be specified in either frames or seconds
    • Option to automatically render the same number of audio channels as source audio
    • ASC CDL metadata extraction from ARRIRAW headers
    • Matte clips can now be assigned to multiple clips in the Media Pool
    • DeckLink 4K Extreme support
    • Added support for the Red Mysterium-X Monochrome sensor (software decode only)
    • Red Rocket can now be disabled from Preferences
    • General performance and stability improvements
    There is a minor database upgrade and we recommend backing up your project dB prior to upgrading. Details are in the user guide.
    Peter
    Rohit Gupta replied 13 years, 7 months ago 8 Members · 10 Replies
  • 10 Replies
  • Joakim Ziegler
    January 18, 2013 at 7:24 am
    Does the Retina support mean it’s no longer necessary to run the 1920×1200-like resolution setting on the MBPr Retina? It’d be nice to be able to step down and not use up all the VRAM for that…
    Joakim Ziegler – Postproduction Supervisor
  • Rohit Gupta
    January 18, 2013 at 10:12 am
    You still need to set the Display setting to More Space for a nice GUI layout. The 1400×900 resolution is too limiting otherwise to show everything properly.
  • Sascha Haber
    January 18, 2013 at 11:39 am
    Great job guys 🙂
    Its really nice to see there is so much development , especially for those new formats.
    I still have high hopes for a working DV workflow or at least the ability to read the DV encoded AVID MXF files I sent you two weeks ago.
    Stability has improved sooooo much.
    I had not a single crash the whole year 🙂
    A slice of color…
    Resolve 9.0.5 OSX 10.8.2
    Colorist / Aerial footage producer
    https://vimeo.com/saschahaber
  • Laco Gaal
    January 18, 2013 at 12:05 pm
    this
    https://forums.creativecow.net/thread/277/22668#22712
    and this:
    https://forums.creativecow.net/readpost/277/22659
    still exists for me when upgraded to 9.1 🙁
    One makes Prores grading almost impossible, other one makes r3d with render cache almost unwatchable.
    Anyway, thanks for the update, I’ll figure out a solution for my problems.
  • Timofey Goloborodko
    January 18, 2013 at 3:55 pm
    This version reset all nodes with lut, and i must manually repair all luts in nodes. :((
    colorist
    https://cinelex.ru/tag/tim/
  • Vivek Vedagiri
    January 18, 2013 at 4:21 pm
    Hi Timofey,
    Could you send logs (captured when you select a clip with such an issue) as well as a project export to davincihelp?
    Regards,
    Vivek
    Vivek Vedagiri
    Blackmagic Design
  • Ryan Wu
    January 21, 2013 at 6:33 pm
    I just installed and updated cuda.
    9.1 crashes as soon as I try to login with my MBP retina.
    9.0 was great anyone got any tips to get this working?
    I’m running OS 10.8
    THX
    R
    THX
  • Ryan Wu
    January 21, 2013 at 6:43 pm
    Really….all I had to do was reboot MBP
    Stupid….can’t believe It never occurred to me.
    All good now.
    R
    THX
  • Joakim Ziegler
    January 22, 2013 at 10:48 pm
    Is the 1920×1200-like resolution still recommended? The whole idea of Retina Display support is that you guys can scale the interface yourself to the size you need, so you don’t have to get the OS to emulate a higher (really lower) resolution display for you. But you might not quite be there yet.
    The thing is, in terms of GPU memory, the OS obviously always allocates its buffers for the 2880×1800 screen. But when you use the emulated modes, it allocates an additional buffer of twice the emulated resolution (in the case of 1920×1200, the buffer is 3840×2400), draws the non-retina aware software’s UI into that, and then scales that whole buffer down to 2880×1800.
    This obviously eats up GPU memory. I often get out of memory errors or other weird behaviour when using this resolution with Resolve, which is why I usually set everything up for render, and then lower resolution to native and restart Resolve to actually render stuff.
    But I’m sure HiDPI displays are something you’re thinking about supporting more completely in the future.
  • Rohit Gupta
    January 23, 2013 at 12:14 am
    It’s not about being retina aware. We are obviously retina aware and therefore can render to the 3840×2400 screen buffer. The non-aware apps gets pixel doubled, and if you look carefully you will notice this in the text and icons, etc.
    Please make sure you are not running any other apps while running Resolve. GPU memory is very limited, and Safari, etc. use a fair amount of it leaving very little for Resolve.
