Activity › Forums › DaVinci Resolve › DaVinci Resolve 7.1 Mac – EDL conforming/re-conforming
  • DaVinci Resolve 7.1 Mac – EDL conforming/re-conforming
    Posted by Matthew Price on January 29, 2011 at 1:20 am
    I am working on the Davinci resolve 7.1 – working on a 1080i project, digitized from HDCAM SR to DPX, import the EDL and go to work… Then I get changes from Online and I should be able to select my new EDL and all the color moves to my new sequence minus the new shots or holes where new shots should be.
    So far I have not be able to figure this out, ether the new EDL has no media linked to it, or the new edits have old shots in the wrong places. I was playing in the config window about using “reel” ID, but I could not get it to work.
    Has anyone seen this?
    Am I missing something basic here?
    I have looking all over the Manual to find direction.
    thanks for your time.
    Matt
    Matthew Price replied 15 years, 8 months ago 5 Members · 5 Replies
  • Mikhail Puzyrev
    January 29, 2011 at 6:12 am
    Open both EDL in text edit and compare. First check reel names – compare with old edl. Choose first event which is in both edls, look at the timecodes and compare to old one. Also check corresponding media for timecode. It will help to figure out what\’s wrong.
  • Thomas Wong
    January 29, 2011 at 7:22 am
    to add to this, is there a way to connect a clip manually if it can’t find the file? I am also having some conform issues with mixed footage from HDV and p2. and i dont’ think the metadata from the EDL is holding up being mixed with r3d. all the r3d links perfect, and just the hdv and p2 don’t link up. It would be great if there was a way just select the black hole clip on the timeline and connect it to the file in my media pool manually and force…
  • Vladimir Kucherov
    January 29, 2011 at 6:32 pm
    First thing I usually do to troubleshoot EDL issues is to check out what the problem is. Basically it’s either the reel, timecode, or both that are off.
    After you load your EDL, look on the conform page, lower left corner. It will show the EDL event as DaVinci reads it – so you can see the reel and TC that Resolve wants to find.
    Then, find the clip in question in the media pool. Look at its reel name. Look at its timecode. Where is the mismatch?
    Now, for any R3D + quicktime based workflow, Reel pattern */%R.* should work for anything where the EDL is generated with Reel from Filename. Essentially Resolve will look at your file, and use anything before the extention (the . ) as the reel.
    I was surprised by this, but I just had to fix a timeline where a few shots were offline. The reel names matched, but timecode on the media pool clip was wrong. These were r3d files. I have no idea if its Resolve’s problem reading timecode or Final Cut’s – I will have to investigate when I have more time, but I fixed it by simply changing the Resolve mediapool timecode to what FCP thought it should be. Clips popped right up after that.
    Manual replacements are possible but clunky (unless I am missing an easier way!). Essentially, you delete the missing clip, and insert a fresh one from the media pool into the hole, then use the slip tool and your reference offline to slip it into position. I would prefer if there was a way to cue up the clip prior to cutting it in but I haven’t seen how to do that yet.
  • Darin Wooldridge
    January 29, 2011 at 7:45 pm
    I play with settings an add back into the media pool after each change. After several combinations i get everything linked. I’ve done two features and several shorts with edls from final cut pro..
    Red, 5d, dpx, qt, you name it.. Always found a way to make it all work.
    NOTE: The comments above are strictly mine, and may not necessarily
    represent those of my employers.
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
  • Matthew Price
    January 31, 2011 at 5:38 pm
    Thx for you reply…
    Some more info.. I am editing on the Avid, outputting a GVG EDL, Then outputting the show to HDCAM SR. Digitizing the tape into the Resolve as DPX, and conforming it to the EDL. This works fine. NOw, when a change in the Avid is made and I try to import that new EDL into the project and have the colored media relink to the new EDL minus the changes… it goes whack… where there should be black holes or extended shots, it seems that it is pulling media from other places or clips around other clips and filling in the holes on its own.
    So maybe the way we are bringing in EDLs is not the right way. Maybe it works fine for the first pass, but once we make changes it can’t keep track?
    Does this change anything you said?
    Thanks!!
    Matt
