Activity Forums DaVinci Resolve DaVinci Resolve 5 (simple) questions
  • DaVinci Resolve 5 (simple) questions
    Posted by Henrik Mark on January 17, 2011 at 3:46 pm
    I have a couple of (simple) questions regarding DaVinci Resolve and i have problems finding themn in the manual which i don’t find that informative:
    1) KEYFRAMING node values
    How do i go about keyframing a value? Let’s say i want the value of 4 on frame 100 turn into value 7 on frame 120 in the same clip – how do i achieve that?
    2) KEYFRAMING windows
    The tracker works really well, but i sometimes want to correct a little bit where it’s inaccurate. I have a hard time figuring out the logic of doing that in the tracker.
    3) HAND tool
    Is there a way to navigate the viewer in “Color” mode, when in actual size mode? LIke pressing the space bar in Photoshop 🙂
    4) GRAIN
    Can you apply grain to your graded footage?
    5 OVERALL adjustment
    I get the idea of the group which works fine. But is there a way of making one (or more) corrections….like a look..be on top of everyting else. To be controlled only once and affecting all clips in a time line. But with the possibility to adjust individually underneath this “look”?
    Hope it makes sense and looking forward to hearing some suggestions to some of my big wonderings!
    Thankyou very much in advance!
    BR
    Henrik
    Rowan Cloete replied 13 years, 10 months ago 8 Members · 9 Replies
  • 9 Replies
  • Margus Voll
    January 18, 2011 at 6:59 am
    5:
    on upper rigth corner you can choose track mode.
    There you can make node that affects the whole timeline.
    Other ides seem pretty good for me 🙂
    Margus
    https://iconstudios.eu
  • Rohit Gupta
    January 18, 2011 at 7:56 am
    – Assuming you are starting on a fresh clip
    – Set the value to 4
    – Go to frame 100
    – Press dynamic on control surface to create a dynamic mark
    – Go to frame 120
    – Hit mark on control surface to create a regular mark
    – Set the value to 7
    If you have already tracked the window, and it has gone off, you would need to adjust the window position in key-frame mode for two frame position and then interpolate between them manually. So, if your clip is from frame 0-100, and the tracker starts going off a frame 80.
    – Go to frame 80
    – Choose Adjust Key Frame radio button
    – Adjust the window for this frame (if required)
    – Press Mark to create a mark point for interpolation (later)
    – To go frame 100
    – Press Mark to create a mark point for interpolation to the previous mark
    – Press the Interpolate “Between” button
    3) HAND tool
    I think you are looking for the middle mouse. Press the middle mouse and drag it around to pan the image in the viewer.
    Hope this helps!
  • Sascha Haber
    January 18, 2011 at 8:10 am
    To 1.
    Is there a way to only store key-frames on one or selected parameters or at least deactivate or delete the others ?
    Sometimes I need to animate things differently and if there are key-frames already, it makes it hard to keep track what has been changes and what is static.
    To 2.
    I love it I love it i love it 🙂
    This works soooo well..
    That alone is worth buying it
    A slice of color…
    DaVinci 7.1 OSX 10.6.6
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Rohit Gupta
    January 18, 2011 at 8:14 am
    1. In the Session Menu, you have a “ALL/Color/PTZR” entry. This controls which lists are marked when you press Mark/Dynamic. There is a button on the Resolve control surface for this as well. So you probably want to leave it on Color.
  • Margus Voll
    January 18, 2011 at 12:10 pm
    On dynamic window you can move keys.
    Margus
  • Kim Krause
    February 18, 2012 at 9:56 am
    thanks for the tip…i’ve been loving resolve and the only thing i miss from color (other than the larger curves and 3 way display size) is the ability to apply a final tweak to the output of all the shots…..your trick works great!
  • Tom Choorapoika
    July 31, 2012 at 4:27 pm
    well…press the middle MB + Command will do the grad function. Have fun!
  • Peter Chamberlain
    August 1, 2012 at 3:56 am
    Hi Kim, in v9 we have the larger curves display you requested. Check it out.
    Peter
  • Rowan Cloete
    October 12, 2012 at 2:31 pm
    Hey there.
    Can’t find anything on this anywhere except for this post, which answered me when I had the same question fro Resolve 8 on SL – any way to hand tool the viewer in Davinci Resolve 9 on OSX Lion – right now it’s bring up the calculator/calendar, etc – Lion seems not to make provision for the Magic Mouse…
