Activity Forums DaVinci Resolve DaVinci Resolve 14.3 is now released
  • DaVinci Resolve 14.3 is now released
    Posted by Peter Chamberlain on February 2, 2018 at 12:56 am
    DaVinci Resolve 14.3 is now released on our support web page.
    https://www.blackmagicdesign.com/support/family/davinci-resolve-and-fusion
    This is a no charge update for all existing customers.
    Important Information regarding Database Management
    DaVinci Resolve 14.3 requires a database upgrade from previous versions. We strongly recommend that you backup your existing database (both DiskDB and PostgreSQL) before performing an upgrade. If you are in the middle of a project you may wish to export that project as well prior to updating the database.
    What’s new in 14.3
    Added support for the Blackmagic Design URSA Broadcast camera
    Added support for RAW footage from the Sony Venice/CineAltaV camera
    Improved the quality of thumbnails in the Media Pool and Edit page timeline on retina monitors
    Added support for reading Panasonic Varicam metadata when importing footage
    Added support for exporting Sony color space and gamma metadata when encoding to MXF
    Added support for RED SDK v7.0.6
    Addressed an issue where the audio section in the Deliver page would default to timeline track instead of the Main bus
    Addressed an issue where editing a transition could sometimes cause a crash
    Addressed an issue where syncing video to audio with a different sample rate results in incorrect audio sync and pitch audio
    Addressed an issue where changes to the Mixer UI layout would not get saved in a dual screen setup
    Addressed an issue where pressing arrow keys to move volume keyframes would not work after opening the keyframe curve editor
    Addressed an issue with the option to pick which node to select when switching clips
    Addressed an issue where a project would fail to save after deleting a group
    Addressed an issue where a project would fail to save after specific undo/redo operations
    Addressed an issue with UI artifacts in the DaVinci Resolve Studio activation window
    Addressed an issue where projects with LUTs would not get exported correctly on Windows
    Addressed an issue where the current project could not be copied between databases
    Addressed an issue where relinking to TIFF files with a higher bit depth would result in a crash
    General performance and stability improvement
    Peter Chamberlain replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
